The query shouldn't stop working when you add other tables... If you put the
query here we may be able to tell you what's wrong.
*Jose C Gomez*
Software Engineer
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
Software Engineer
E: jose@...
On Sun, May 8, 2011 at 4:32 AM, Mark Kamsika <m.kamsika@...> wrote:
> I used matches like you suggested.
> Unfortunately the query stops working when adding other tables to the
> query.
> Luckily enough we use the field needed in abbreviated form in the part
> search So
> this will do for now
> Mark
> From: Jose Gomez <jose@...>
> To: vantage@yahoogroups.com
> Sent: Fri, 6 May, 2011 15:36:46
> Subject: Re: [Vantage] BAQ's
> How'd you solve it?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Fri, May 6, 2011 at 10:02 AM, Mark Kamsika <m.kamsika@...>
> wrote:
> > Please Ignore,
> > I have got this working
> > From: Mark Kamsika <m.kamsika@...>
> > Sent: Fri, 6 May, 2011 14:59:25
> > Hi,
> > I have used matches but it does not give me any matches. Any Ideas.
> > The SQL query brings up results
> > Mark
> > Sent: Fri, 6 May, 2011 14:00:17
> > sure use matches
> > select partnum, ud101.character01 from part, ud101 where part.character09
> > like
> > ud101.key1
> > The data types are incompatible so like is used instead of equals
> > for each Part, ud101 where Part.Character09 MATCHES(UD101.Key1)
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Fri, May 6, 2011 at 8:27 AM, Mark Kamsika <m.kamsika@...>
> > wrote:
> > > Hi all,
> > > I am trying to write a BAQ which queries a ud table. In sql server the
> > > query
> > > would be:
> part.character09
> > > like
> > > ud101.key1
> > > Is it possible to run a BAQ with a like statement.
> > > Kind Regards
> > > Mark
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
