Hi folks, we recently upgraded from 10.2.300 to 2021.2. This has been a pretty smooth transition. But, I have a problem with a customization we did to the Purchase Advisor form. I used a BAQ Data View to replace the supplier price list grid. When I use the form now, the grid is empty. I have used “Test Code”, and it comes back as “Compiled Successfully”, so I don’t think I have any syntax errors. I have also verified that the grid is set to use “PurchAdvisorPriceListBAQ” as it’s collection. Is the problem that I am re-using the grdSupplierPartList grid? I’m not a full time programmer, and figured out how to use BAQDataView from posts on this forum. Are their changes in Kinetic I need to use to make this work?
// Custom code for PurchaseAdvisorEntryForm
// Created: 5/6/2022 3:36:10 PM
extern alias Erp_Contracts_BO_PartOnHandWhse;
extern alias Erp_Contracts_BO_Part;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.Lib.Broadcast;
public class Script
BAQDataView baqAdvPriceList;
CreatePriceListBAQView();
public void CreatePriceListBAQView()
baqAdvPriceList = new BAQDataView("PurchAdvisorPriceList");
oTrans.Add("PurchAdvisorPriceListBAQ",baqAdvPriceList);
string pubBinding = "Part.PartNum";
IPublisher pub = oTrans.GetPublisher(pubBinding);
if(pub==null)
oTrans.PublishColumnChange(pubBinding, "MyCustomPublish");
if(pub !=null)
baqAdvPriceList.SubscribeToPublisher(pub.PublishName, "VendPart_PartNum");
// Begin Custom Code Disposal
// End Custom Code Disposal
Thanks, I added an new ultraGrid, and used the GUI to select the collection. It’s connecting, because I see the correct column headings (they match what is in the BAQ). But it’s just not pulling the data into the grid.
So I rewatched the video here: BAQ Dataview Example Video - #35 by Banderson and updated my customization.
(Direct link to YouTube video by Carson: Epicor BAQ DataView - YouTube )
I have it working now. I think I had some confusion about where to put the BAQ name. In the code below, my BAQ is named “PurchAdvisorPriceList”
using System;
using System.Data;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
public class Script
BAQDataView AdvPriceListDV;
CreatePriceListBAQDV();
public void CreatePriceListBAQDV()
AdvPriceListDV = new BAQDataView("PurchAdvisorPriceList");
oTrans.Add("PurchAdvisorPriceList",AdvPriceListDV);
string pub1Binding = "Partlist.PartNum";
IPublisher pub1 = oTrans.GetPublisher(pub1Binding);
if(pub1==null)
string pubName = Guid.NewGuid().ToString();
oTrans.PublishColumnChange(pub1Binding, pubName);
if(pub1 !=null)
AdvPriceListDV.SubscribeToPublisher(pub1.PublishName, "VendPart_PartNum");
