Baq
Thank you!!
Ok, so no one uses the ASP page generation in 6.1, I can live with that.
Does anyone use the Business Activity Query in general? I have been
setting up some calculated fields and am looking for pointers on just
what you can do within a calculation. Today I determined that I can use
if...then...else statements within the calculated field, I knew about
column-label from examples that existed before, but I am still trying to
work out the use of format. Any thoughts there?
Aaron Hoyt
Hittite Microwave Corporation
You can do things like:
Part.Character01 + "" format "x(25)" label "Engineer"
Adding the null field (not intuitive) forces it to recognize the format and
label... otherwise you get "character01" as the column heading.
Numeric formats are like ">>>,>>>.99" but there's a bug (SCR 8006) when the
query uses this format on the dashboard. You get ">" instead of the number
in that position.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, May 21, 2004 10:19 AM
Subject: [Vantage] BAQ
> Aaron Hoyt
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
Thank you Chris,
I will have to add myself to this bug SCR. I thought it was just me
with the number format thing.
Have you tried any programming techniques within the formula like the
if...then...else. I found I could do that little trick by just trying
it. I was wondering if there is any way to get documented just what the
limits are.
Aaron
Sent: Friday, May 21, 2004 2:07 PM
Subject: Re: [Vantage] BAQ
and
the
number
in that position.
that.
use
to
> Aaron Hoyt
and
> Yahoo! Groups Links
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
You can use Progress documentation... the Business Activity Manager creates
a Progress program to run.
Sent: Friday, May 21, 2004 11:17 AM
Subject: RE: [Vantage] BAQ
> Thank you Chris,
> limits are.
> Aaron
> From: Chris Robisch [mailto:blue.wine@...]
> and
> the
> number
> in that position.
> From: "Aaron Hoyt" <hoyt@...>
> that.
> use
> to
> > Aaron Hoyt
> and
> > Yahoo! Groups Links
> _____
> Yahoo! Groups Links
> Yahoo! Groups Links
In the business activity query, I am making a calculated field. What
code do I need to write in?
Ben
Recently I was creating a new BAQ and my system locket up. When I do a
search for a BAQ the name shows up in the search, but when you select
it no data comes in. I have found that the BAQ data is stored in the
QueryCalcFld, QueryField, QueryLikeRef, QueryRelation,
QueryRelationField, QuearyTable, and QueryWhereItem. Does anyone know
where the system stores the information that the BAQ Search pulls it
information from?
Steve
Session lock ups during large data set returning BAQ execution is the norm - not the exception. The BAQ is reading the abstract db table views directly. The tables you refer to are simply to hold and store the definition/details of the BAQs themselves.
rmgfelm <vantage@...> wrote: Recently I was creating a new BAQ and my system locket up. When I do a
information from?
Steve
Never miss a thing. Make Yahoo your homepage.
Robert,
This was a small BAQ. The system has a bug when selecting to view some of
the files in like the repsplit2 in the order detail table it gives an error
message saying that the file can not be found and then disappears from the
selection in the BAQ. This then creates a string of errors and will not let
you save the BAQ. When I tried to delete the BAQ the system locked up and
now when you try to search and select the BAQ it returns the name in the
menu bar, but nothing in the BAQ itself. I removed all the files in the
tables listed below for that BAQ, but you can still see it if you search for
it. There must be one other table with some information the still lists
some information on the BAQ.
I currently have (3) BAQs in this state and was working with one of them to
see if I can clear them out of the system. I am waiting on a patch to fix
the current problem that is reported and listed as fixed in version
8.03.40x, but is still in the 8.03.305 patch level.
Do you know of another table that would go with what I had listed?
Steve
Sent: February 26, 2008 3:48 PM
information from?
Steve
Can someone tell me what that field "KeyID" is and what does it do on BAQ's
table join screen.
Vantage automatically puts "PartRevAltMethod" in.
The KeyID is what tells the BAQ how different tables coordinate with
each other. For example, if I want to link OrderHed & OrderDtl, the
KeyID field will list something related to OrderNum and in the window
right below you'll see it links Company & OrderNum between both tables.
Thus when a BAQ result from OrderHed for order #1234 shows, the OrderDtl
for that same order comes along.
99% of the time the system will automatically put the proper links in
and you don't have to do anything on this screen (such as you listed
below with it putting PartRevAltMethod). I've created more than a
hundred BAQ's and I can think of only one time I had to manually define
my links.
Of Bill Wu
Sent: Friday, April 25, 2008 7:06 AM
BAQ's
table join screen.
Thank you Ken for the answer, let me make sure I understand this correctly.
this KeyID is the key for this specific join that BAQ uses for itself. I do
not need to do anything with it. However, as far as what this key means, I
need to use the field relationship to define the join detail, such as
PartNum from one table equals the partNum in another table, Correct? Because
in a normal SQL join, you don't have this KeyID, that's why I'm confused.
Bill
_____
Ken Williams
Sent: Friday, April 25, 2008 9:25 AM
my links.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Bill Wu
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
BAQ's
table join screen.
The key is the same as the index fields common to both tables. They are
very important for how the query selects the records and how efficient the
query runs.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-0162 a Fax 401-596-1050
www.maxsonautomatic.com <http://www.maxsonautomatic.com/>
_____
Bill Wu
Sent: Friday, April 25, 2008 11:49 AM
Bill
_____
Behalf Of
Ken Williams
my links.
Behalf
Of Bill Wu
BAQ's
table join screen.
The KeyID, I believe, is a shortcut to a predefined join. Check the
Dataset Relationships entry (I think I created a shortcut to it directly
under System Management, I can't remember where it was by default).
So think of it as a shortcut to the normal joins you're used to.
Of Bill Wu
Sent: Friday, April 25, 2008 9:49 AM
correctly.
do
I
Because
confused.
Bill
_____
Behalf Of
Ken Williams
my links.
Behalf
Of Bill Wu
BAQ's
table join screen.
I can not see ECOMtl.MtlPartNumPartDescription, ECOMtl.OpDesc fields
on BAQ that I created, however I am able to see those in Customization
mode in Engineering Workbench application. Other fields seems to be
alright yet I can retrieve information I needed. Anyone encountered
this before?
TIA
BAQ's work on the actual tables.
Customization land / UI work on datasets which are in effect views of
the tables.
i.e. they contain descriptions auxiliary related information and
calculated fields generated from the business layer accessing the
tables, it's a level of abstraction.
You need to create the required relationships and calculations to
recreate the required items in your baq.
Of empedole
Sent: 04 September 2008 21:32
this before?
TIA
The views you see in applications in developer mode are just that: views (not necessarily the 'real' tables accessible via BAQs).
Check you application view fields using data tools to see what it is "like"... That might give you a hint as to where the data really resides (and where you can get to it from a BAQ).
Rob
Date: Thursday, September 4, 2008, 4:32 PM
I can not see ECOMtl.MtlPartNumPa rtDescription, ECOMtl.OpDesc fields
this before?
TIA
Hi,
I created a BAQ to mimic Time Phase The reason is customer service wanted a
Dashboard to view price breaks and availability of parts and PO promise
date.
I got everything to work except when you add a second PO for the same part
it shows the second line but does not give the running total of all PO to
that part number.
Code I used is :
(PartWhse.OnHandQty - PartWhse.AllocQty + PODetail.OrderQty)
Best regards,
Ennio Verderese
date.
that part number.
Code I used is :
Best regards,
Ennio Verderese
I am trying to create a BAQ that adds all the cost of a part and then
multiplies that total by the on hand qty. The formula below is not working,
what am I doing wrong, thanks in advance.
Part.AvgMaterialCost + Part.AvgLaborCost + Part.AvgBurdenCost +
Part.AvgSubContCost + Part.AvgMtlBurCost * PartBin.OnhandQty
Paul Smith
Inventory Management
233 Ballston Ave
Saratoga Springs NY, 12866
518-245-4358
