The selection options will no allow me to increase over 200. This is when I select a BAQ from an application or straight from the BAQ with “Rows to Return” set to All. New to Epicor and really like this site.
BAQ 100line Max.pdf (80.4 KB)
We are testing prior to upgrading and I saw this same thing yesterday and found how to work with it (through some trial and error). The list initially shows 200 but if you scroll down, it will allow you to scroll past 200. You will see that if you checked “All” or whatever to select all, only 1-200 are checked. When I was past 200, I hit it again (All) and everything through the screen I was looking at was checked.
Also, it looks like regardless of how many are displayed, if you export to Excel or “copy all including labels”, all of the data in the BAQ will be exported or copied, not just the top 200.
