BAQ Table Relations Issue
There is a bug in this version that bit us also... BAQs in 9.04.507A cannot properly relate more than two tables.
Call Epicor support and request SCR 78693.
Ernie Lowell
Diba Industries
--- In vantage@yahoogroups.com, "mike.numbers" <mnumbers@...> wrote:
> I have a BAQ that has 5 tables. When I look at the table relations, all of the tables have the same relationships, even though the fields are not in the table. When I look at the General view the relationships are confirmed on that screen. Right now the BAQ is working, but I need to add a new table and when I do that I get an error saying I have "More that 1 root table". When I delete the relationships from one table, they get deleted from all table relationships. Any ideas on how the fix this?
> 9.04.507a
> Mike
9.04.507a
Mike
It sounds like the BAQ has gotten corrupt somehow. I've seen this happen a
few times. Try exporting and importing the BAQ or just copying the query.
If I recall, that has fixed them once or twice for me.
If that doesn't do it, you may be stuck rebuilding the query. Hopefully
with only five tables it shouldn't be too bad.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> 9.04.507a
> Mike
I tried exporting and importing got the same relationships. Tried copying
got the same relationships. Tried to start a new BAQ and ended up with all
relationships being the same even though some of the fields were not in each
of the tables.
Sounds like a Epicor BAQ problem?
Mike
John Driggers
Sent: Wednesday, September 26, 2012 11:28 AM
Subject: Re: [Vantage] BAQ Table Relations Issue
If that doesn't do it, you may be stuck rebuilding the query. Hopefully with
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> 9.04.507a
> Mike
What tables are you trying to join? When dragging tables on the design tablet, it will try to make a join based on what it thinks from field names and other information. This join may not be a good one and you may need to tweak/correct. Also depending on the order you bring the tables in the direction of the joins may be off. Generally the arrows should point in one direction UP or Down the hierarchy of the tables.
Jim Kinneman
Encompass Solutions, Inc
> of the tables.
> Mike
> John Driggers
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > 9.04.507a
> > Mike
Just to double check, you're clicking on the links themselves correct? Not
the table? If you click the table it won't update the relationship view and
you'll just keep seeing the same stuff.
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> Jim Kinneman
> all
> each
> > of the tables.
> > Mike
> Behalf Of
> > John Driggers
> a
> with
> > *John Driggers*
> > *:: 904.404.9233
> > :: waffqle@...
> error
> > > 9.04.507a
> > > Mike
> have
Problem solved. My laptop died last week and my new one was loaded with a
"bad" version of Epicor. Reloaded Epicor904 and all is well.
Thank you everyone for your input.
Mike
John Driggers
Sent: Wednesday, September 26, 2012 1:28 PM
Subject: Re: [Vantage] Re: BAQ Table Relations Issue
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> Jim Kinneman
> > copying got the same relationships. Tried to start a new BAQ and
> > ended up with
> all
> > in
> each
> > of the tables.
> > Mike
> Behalf Of
> > John Driggers
> > happen
> a
query.
> > Hopefully
> with
> > *John Driggers*
> > that?*
> > *:: 904.404.9233
> > :: waffqle@...
> > > get an
> error
> > > 9.04.507a
> > > Mike
> > must
> have
> > Builder and Crystal Reports and other 'goodies', please goto:
