BAQ syntax help
Epicor 9.05.701
I think the below syntax (in a BAQ calculated field) is fairly explanatory…it works out the ASSY2 part fine, but doesn’t do anything for ASSY1…it must be something to do with my syntax near “AND”?
IF(JobOper.OpCode = “A2DAS2” OR
JobOper.opcode = “ASMAS2” OR
JobOper.opcode = "T2SAS2"then “Assy2” else “”) AND
IF(JobOper.OpCode = “A2DAS1” OR
JobOper.opcode = “ASMAS1” OR
JobOper.opcode = "T2SAS1"then “Assy1” else “”)
Many thanks in advance.
JobOper.opcode = "T2SAS2"then “Assy2” else IF(JobOper.OpCode = “A2DAS1” OR
JobOper.opcode = "T2SAS1"then “Assy1” else “”))
worked a treat. Thank you.
