Thanks for the help and great advice. That got us going again.
Ed
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
bring it back into the BAQ designer app.
screen.
application which (natively) has a view into the table.column will
then have that BAQ available from its Search window as a BAQ Search.
applications. Example: Our Job Entry has 24 available BAQ searches
(all with archane company code prefixed names that aren't
particularly inutitive to users).
user (based on the BAQs) for ONLY what they will commonly need to do
their normal jobs.
Ed
wrote:
>want with no erros (and exported to xml for safekeeping, close it and
> Once the BAQ is designed, analyzed and tested to be doing what you
>fields in your BAQ in the left 'Available "Like" Columns pane of the
> The far right tab called BAQ Search should then list all the table
screen.
>control) to the right pane 'BAQ Search "Like" Column', any
> By selecting a listed table.column and moving it (with the arrow
>dozens of BAQs available for use as BAQ searches for particular
> ...A piece of advice: Over time, you can end up having dozens and
>their lives more productive, create specific Named searches for each
> Most users really only need 3-6 of these searches - so to make
their normal jobs.
>different named searches.
> Named searches are stored as personalizations so each user can have
>part
> Rob Brown
> --- On Thu, 6/5/08, egarbowski <egarbowski@...> wrote:
> From: egarbowski <egarbowski@...>
> Subject: [Vantage] BAQ setup question
> To: vantage@yahoogroups.com
> Date: Thursday, June 5, 2008, 12:17 PM
> We're new to Vantage and are trying to setup a BAQ to search for
> numbers by the Customer's part number. Now that the query is setup,how
> do we make it accessible from a Part Search window? We havenot
> the 'Shared' box checked in the BAQ setup window but it still does
> show up in the list under the BAQ tab when we do a Part search.
