BAQ run stats
Does anyone know of a feature in Epicor or a table that can be queried to return usage metrics on a BAQ (i.e. number of times run, runtime, etc)?
You can make a BPM to write to a UD table. The BO is DynamicQuery. There are 2 methods that get called, Execute or GetList depending on if the BAQ is updateable or not. The QueryID and userid are in there, along with other data.
Here is what I use. I think it is from an @knash post.
It only tracks that a baq was used. I have 600+ and am trying to weed out non used ones for the move to the browser UX
Track BAQ Usage.bpm (41.2 KB)
Thanks, that’s a great idea!
red_herring1
That was a red herring, but I finally found it:
@klincecum Not that one. What I made was with widgets and I would only do that if I had one to copy. Now I am on the hunt for where it came from.
It was @markdamen not @knash that I copied the picture from.
You also might like to take a look at Epicor’s Menu Usage Tracker. However, if you’ve already created the BAQ and/or BPM previously suggested, then the Menu Usage Tracker might not have enough additional benefit to be worth the licensing cost.
