Thanks. I'm not seeing Solution Manager in V8. I found it in E9 but I can't get the help menu to function, so I might be working on a trial and error basis.
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> Don't know, give it a try.
> (We went from 6->9, there were enough schema changes we just rebuilt all
> reports in 9.05 test).
> Brian.
> Of Sean Toler
> Sent: Thursday, September 27, 2012 10:51 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BAQ Reports in E9
> Can it copy from V8 to E9?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Brian Roberts" <broberts@> wrote:
> > Look at Solution Manager (Sys Mgmt -> Utilities). Can copy all BAQs,
> > dashboard, customizations, reports etc from one database to another.
> > The day of your go-live export everything from test & import into
> live.
> > Brian.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of kosmoqa
> > Sent: Thursday, September 27, 2012 10:18 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Just out of curiosity, if we start rebuilding the BAQ Reports within
> the
> > test environment, would the changes carry over once we went live with
> > E9?
> > "Sean Toler" <seantoler@> wrote:
> > > That doesn't sound like much fun.
> > "dhilliard35" <dhilliard35@> wrote:
> > > > So much has changed between versions you will have to rebuild all
> of
> > your reports. We just upgraded from 6.1>>8.0>>9.05.700c and I just
> went
> > through this same thing. There will be certain things that get pulled
> > through the conversions but most if not all will need to discarded and
> > then rebuilt.
> > > > > We're currently running V8, but we just had our E9 test
> > environment installed today. I haven't had much time to look at it,
> but
> > at first glance I've noticed that all of the custom BAQ Reports that I
> > have created over the years are now missing. Has anyone else seen
> this?
