We recently upgraded to 2024.2.10 in our Pilot environment and now BAQ Reports using SSRS Breaking/Routing to send emails are erroring. Has anyone else experienced this? If so how did you resolve?
Error we are getting is: Failed to launch task to submit report. Error: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
—> Ice.Api.Exceptions.UnknownRestException: HTTP Error 404.0 - Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
@Hally Nothing has changed in our email or Reporting settings so unless the upgrade now requires a different setup that we didn’t have before I don’t believe that is the issue. This is working in our Production environment which is still on 2024.1.15
Might be worth a sanity check, just to be sure… Other area to check may be the system agent user details, but if other reports etc are running then I doubt it…
Found the issue…In the data directive Auto Print setup the Run Schedule was set to Immediate. I changed this to Queued and the email now sends. Prior to 2024.2.10 using Immediate worked I found this suggestion in another user group post Bartender RDD from BAQ - #7 by DaveOlender
