BAQ Report Query Question
I'm not sure what result you are looking for, but I think that the
fields you chose for linking sound perfectly reasonable.
What I would do next is try some troubleshooting methods like this:
Display these 2 fields in your BAQ and rerun it:
LaborDtl.LaborHedSeq and
LaborDtl.LaborDtlSeq.
LaborDtl.Company plus LaborHedSeq plus LaborDtlSeq should represent a
single unique record in your LaborDtl table. If your BAQ is
returning more than 1 record for each LaborHedSeq+LaborDtlSeq, then
there is a linking error somewhere.
If there is only 1 row returned, then your linking is probably fine.
In that case, there is probably something wrong with your logic.
Displaying additional fields from the tables will help you determine
why you are getting more rows than you are expecting.
Print out the Data Dictionary for each of your 3 tables to help you
decide what additional fields to display for troubleshooting purposes.
Also, in my experience, the BAQ phrase builder can be stubborn. I
have found that it helps if I close the BAQ and re-open it from the
menu frequently while troubleshooting a complicated BAQ. It seems to
give it a "boot" and "get rid of any old bad memory shadows".
A side note: I assume that since you are not using the Company field
for linking that you do not have the Multi-company module. However,
it is always a good practice to include the Company field in all of
your relationships.
Lynn
--- In vantage@yahoogroups.com, "brucewbrannan" <bruce.brannan@...>
wrote:
> Wait... it only fixed part of it.
> All of the operations show up now (even with zero hours applied)
but
> the labor hours are grossly inflated.
> It seems like the new join is backward. JobOper is related to
> LaborDtl on Company, JobNum, AssemblySeq, and OpSeq. I wonder if
it
> is quadrupling the labor records for each field (redundant joins?).
> --- In vantage@yahoogroups.com, "brucewbrannan" <bruce.brannan@>
> wrote:
> > You're both right, I didn't notice that box. That fixed it.
> > Thanks!
> > --- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@> wrote:
> > > Don't resort to ODBC. There are too many reasons to use BAQs
> > instead
> > > of ODBC.
> > > It sounds like you just forgot to check the "Outer Join" box on
> > your
> > > relationship between tables JobOper & LaborDtl.
> > > Lynn
<bruce.brannan@>
> > > wrote:
> > > > I've got a BAQ with JobHead, JobOper, and LaborDtl. The
report
> > is
> > > used
> > > > to show the Operation hour estimates alongside the hours
> charged
> > to
> > > the
> > > > operation from the labor entries. The Crystal report works
> great
> > > but
> > > > it only shows the operations that have hours charged to them.
> > > > This sounds like a join problem but within the Phrase Builder
> in
> > > BAQs,
> > > > I can't figure out how to change the join. I have JobHead
> linked
> > > to
> > > > JobOper on the JobNum. And then JobOper to LaborDtl linked
on
> > > JobNum,
> > > > Asy, and Oper fields and. I can see why this only shows Ops
> > where
> > > > there is labor applied but I don't know how to fix it using
> > Phrase
> > > > Builder. My next attempt is to rebuild the report in Crystal
> > using
> > > > ODBC but I'd rather stick with the BAQ report to prevent
having
> > to
> > > > setup ODBC on all of our client PCs.
> > > > Any ideas?
> > > > Thanks
I've got a BAQ with JobHead, JobOper, and LaborDtl. The report is used
to show the Operation hour estimates alongside the hours charged to the
operation from the labor entries. The Crystal report works great but
This sounds like a join problem but within the Phrase Builder in BAQs,
I can't figure out how to change the join. I have JobHead linked to
JobOper on the JobNum. And then JobOper to LaborDtl linked on JobNum,
Asy, and Oper fields and. I can see why this only shows Ops where
there is labor applied but I don't know how to fix it using Phrase
Builder. My next attempt is to rebuild the report in Crystal using
ODBC but I'd rather stick with the BAQ report to prevent having to
Any ideas?
In Phrase Builder go to the screen of Table Relations where it shows Jobhead linked to JobOpr etc. In the Table Relations grid there is a checkbox to the far right that is labeled OuterJoin. Check these boxes to change the link from Inner Join to Outter Join.
Â
Email me if you can not find it and I will email the page from the book showing this.
Â
Doug
--- On Wed, 2/4/09, brucewbrannan <bruce.brannan@...> wrote:
Subject: [Vantage] BAQ Report Query Question
Date: Wednesday, February 4, 2009, 11:44 AM
Any ideas?
Don't resort to ODBC. There are too many reasons to use BAQs instead
of ODBC.
It sounds like you just forgot to check the "Outer Join" box on your
Lynn
used
the
but
BAQs,
to
JobNum,
> Any ideas?
> Thanks
Thanks!
instead
> of ODBC.
your
> Lynn
is
> used
to
> the
> but
> BAQs,
> to
> JobNum,
where
Phrase
using
to
> > Any ideas?
> > Thanks
All of the operations show up now (even with zero hours applied) but
LaborDtl on Company, JobNum, AssemblySeq, and OpSeq. I wonder if it
> Thanks!
> instead
> > of ODBC.
> your
> > Lynn
> is
> > used
charged
> to
> > the
great
> > but
in
> > BAQs,
linked
> > to
> > JobNum,
> where
> Phrase
> using
> to
> > > Any ideas?
> > > Thanks
