I’m working on editing one of our current BAQ Reports, and having an issue with setting up the Option Fields. From the screenshot, the issue is with the EmployeeNum field. When I run the report it seems that that field is limited to 5 characters. I need it to accept a 6 character input now, but I don’t see a way to format what can be input. Is this 5 character limit a hard limit, or is there something I can edit to extend it?
What does the calculated field look like in the BAQ for EmployeeNum?
Here’s a screenshot of all the fields. I have tried changing the format here before, but it didn’t seem to affect the report.
@bordway wants to see the definition of your calculated field. Click your calculator button and show the definitoin of EmployeeNum.
Ah my mistake, It’s just the UD field, I think it’s only a calculated field so it doesn’t say ‘Number01’ to the user when they run the report.
I figured out a way to make this work. I don’t know if it was both of the things I did or just one, but here’s what I did. I synced the report data set in Report Style, then I deleted the Option Field in BAQ Report Designer and remade it. After that it took on the format I had set in the BAQ display fields.
