hi
What tables do you have in your BAQ? I am assuming you have the PO Header table included.
And you added the POType field to the BAQ.
Did you look at adding an option instead of a filter? Like I said before - Filters are usually used for major keys (custid, vendid, SO Number, etc....). The PO Type is not a key field. If the field is available in the Options tab
then you could add it there (options is like a filter).
if the field does not show up under options, I would need to see if I can recreate it so I can give you other suggestions. So if you can tell me what tables you are using and how you are linking them. I can see what I can do.
Marianne
