BAQ Report Blank Title 83353
Hi Paul,
I'm not sure why you'd want to use this query.
The way you have it it's only looking for warehousecode=''. Unfortunately
there isn't a wildcard. However, if you summarize this table you can create
a formula which can then do a sum( <formula> ) and will get you the desired
results.
Not knowing how you are bringing in the PartTran or what your end result is
I'm just offering what I see at this point.
--Sean
Paul Smith
Sent: Wednesday, March 17, 2010 1:32 PM
To: Vantage
Subject: [Vantage] BAQ Report
Group
I am looking for a report that needs to pull information from several
different warehouses. Is there a wildcard I can use to specify search in
every warehouse? The BAQ code is below. Thanks in advance
and PartTran.WareHouseCode = ' ' and
Paul Smith
I have created a BAQ report and in the report form I want to set the
archive period to one week. Easy choice. However, under the actions
menu where I would typically go to Save the Defaults, everything is
grayed out and it won't allow me to save any changes. What am I
missing?
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Was it created with a different user ID?
Of Rob Bucek
Sent: Wednesday, September 30, 2009 9:18 AM
missing?
Rob Bucek
FAX: (715)284-4084
I created it under the same user ID I am currently trying to modify it
with..
Rob Bucek
FAX: (715)284-4084
Of Vic Drecchio
Sent: Wednesday, September 30, 2009 8:24 AM
Subject: RE: [Vantage] BAQ Report
Behalf
Of Rob Bucek
missing?
Rob Bucek
FAX: (715)284-4084
Rob,
I get that on all my BAQ reports. I don't know if it can be changed.
If you want an alternative you could put this in to a customization on the
BAQ front end. This would make it global.
Private Sub BAQReportForm_Load(ByVal sender As object, ByVal args As
EventArgs) Handles BAQReportForm.Load
'// Add Event Handler Code
Dim edvReportParam As EpiDataView =
CType(oTrans.EpiDataViews("ReportParam"), EpiDataView)
edvReportParam.dataView(edvReportParam.Row)("ArchiveCode") = 7
End Sub
I suppose you could look at the sessionid if you wanted it to be specific to
a user or group of users.
Ross
Rob Bucek
Sent: Wednesday, September 30, 2009 8:18 AM
missing?
Rob Bucek
FAX: (715)284-4084
Hey Ross,
Thanks for the input! Making it a global parameter via customization
would be a very acceptable solution to this. I didn't know you could do
that with VB customization...Thanks a lot!!
Rob Bucek
FAX: (715)284-4084
Of Ross Hughes
Sent: Wednesday, September 30, 2009 9:38 AM
Rob,
the
End Sub
specific to
Ross
Behalf Of
Rob Bucek
missing?
Rob Bucek
FAX: (715)284-4084
have
and
Group
Paul Smith
