Hi All,
Â
I had the Same Issue, TO Resolve this Export the BAQ in to a CSV File format using Business Activity Quer Export Process ,that how ir retrieves the whole Data..Â
Â
SOme times After the Export you see that all the coloumns are not alligned properly & the Test Breaks into multiple lines, To Resolve this Use the Text Limitation for the Description Field in the BAQ to display only 50 charecters.
Â
Hope this Helps.
Â
Doma Reddy.
Â
Â
Â
Hope this Helps.
Â
Doma Reddy.
--- On Tue, 3/29/11, Chris Thompson <chriselectrix@...> wrote:
Subject: Re: [Vantage] BAQ Question
Date: Tuesday, March 29, 2011, 8:06 AM
Â
We are on 9.04.505C and progress 10.1c.
Any help would be massively appreciated as its annoying (especially since there
appears to be nothing wrong with the BAQ).
Sent: Tue, 29 March, 2011 13:59:21
I have the same issue with a BAQ to retrieve all quotesmtl linked to the sales
order.
I guess if the dataset gets too big it crashes.
If anyone has a idea how to prevent this it will be greatly appreciated.
We are on epicor 9.04.507A and progress 10.1c.
Ephraim Feldman
Programmer / Analyst
Axis Lighting
Sender: vantage@yahoogroups.com
Date: Tue, 29 Mar 2011 13:36:10
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] BAQ Question
Hi All
I have created a BAQ which works beautifully. It shows all JobMtl.PartNum
required for each parent job (JobMtl.JobNum) and displays if there any jobs or
purchase orders for these 'sub-assemblies'.
for each JobMtl no-lock where JobMtl.JobNum = '011746' , each Part no-lockÂ
where (JobMtl.Company = Part.Company and JobMtl.PartNum = Part.PartNum ) ,Â
each PartWhse no-lock outer-join where (Part.Company = PartWhse.Company and
Part.PartNum = PartWhse.PartNum ) , each JobHead no-lock whereÂ
ISNULL(JobHead.JobComplete)Or (JobHead.JobComplete = FALSE And JobHead.JobNum <
'a' ) , each JobOper no-lock where JobOper.OpComplete = FALSE outer-join andÂ
(JobHead.Company = JobOper.Company and JobHead.JobNum = JobOper.JobNum ) , each
PODetail no-lock where PODetail.OpenLine = TRUE , each POHeader no-lockÂ
where POHeader.OpenOrder = TRUE outer-join and (PODetail.Company =
POHeader.Company and PODetail.PONUM = POHeader.PONum ) , each Vendor no-lock
outer-join where (POHeader.Company = Vendor.Company and POHeader.VendorNum =
Vendor.VendorNum )outer-join and (Part.Company = JobHead.Company and
Part.PartNum = JobHead.PartNum )outer-join and (Part.Company = PODetail.Company
and Part.PartNum = PODetail.PartNum ).
However, if I filter the BAQ as above (JobMtl.JobNum='011746') it works
perfectly and returns the results in a reasonable time.
If I leave the criteria off, the BAQ crashes.
I know there is a lot of information that needs to be retrieved, but it should
still work shouldnt it?
  Â
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
http://groups.yahoo.com/group/vantage/files/.%c2%a0
