BAQ Parts in Inspection
I am trying to run a BAQ that tells me what parts are in inspection. Similar to the Inspection Processing search:
I cannot find a table that gives me this information.
I have a baq that uses the NonConf table to show if there is an inspection pending. I think that might be what you are looking for? Not sure though on how you are using inspection as to whether that will catch everything in inspections. Give it a shot.
Similar topic related to the Inspection Processing search screen. I am trying to write a quick search that is more Lot Number friendly. I am having trouble understanding what I need to do to make the quick search available to this form, since the search binoculars doesn’t seem to be tied to a key field…
Hey Aaron, Funning seeing you here! You probably need to go into the way back machine, but did you ever figure out a way to include a lot number search in inspection processing?
Hey Nick, yeah I’m kind of a bum and like hanging out here :slight_smile:
I think what I did (it’s been a while) was add in some code to invoke an adapter for Quick Search and call a quick search (including my lot number) and pull back the inspection records associated with the search.
// Custom code for InspectionProcessingEntryForm
// Created: 12/5/2017 11:39:08 AM
// Modified: 12/5/17 AMM
// Add custom tool to actions menu that allows one to search by special parameters
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using System.Collections;
using System.Collections.Generic;
public class Script
	private EpiDataView edvporView;
	private EpiDataView edvuiView;
	private ReceiptAdapter adapterReceipt;
		this.InspectionProcessingEntryForm.BeforeToolClick += new Ice.Lib.Framework.BeforeToolClickEventHandler(this.InspectionProcessingEntryForm_BeforeToolClick);
		this.edvporView = ((EpiDataView)(this.oTrans.EpiDataViews["porView"]));
		this.edvuiView = ((EpiDataView)(this.oTrans.EpiDataViews["uiView"]));
		this.InspectionProcessingEntryForm.BeforeToolClick -= new Ice.Lib.Framework.BeforeToolClickEventHandler(this.InspectionProcessingEntryForm_BeforeToolClick);
		this.edvporView = null;
		this.edvuiView = null;
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	//custom tools
	public void AddCustomTool()
		if(!baseToolbarsManager.Tools.Exists("ActionsMenu")) return;
		var actionsMenu = baseToolbarsManager.Tools["ActionsMenu"] as Infragistics.Win.UltraWinToolbars.PopupMenuTool;
		if(actionsMenu==null) return;
		var tool = new Infragistics.Win.UltraWinToolbars.ButtonTool("Disposition Fresh Donor Lots");
		tool.SharedProps.Caption = "Disposition Fresh Donor Lots";
		baseToolbarsManager.Tools.Add(tool);
		actionsMenu.Tools.Add(tool);
		actionsMenu.Tools[tool.Key].InstanceProps.IsFirstInGroup = false;
	//Launch special search form
	private void InspectionProcessingEntryForm_BeforeToolClick(object sender, Ice.Lib.Framework.BeforeToolClickEventArgs args)
		if(args.Tool.Key == "Disposition Fresh Donor Lots")
			//launch special search //TODO
			object ret = ProcessCaller.InvokeAdapterMethod
						(oTrans.EpiBaseForm, "QuickSearchAdapter", "ShowQuickSearchForm", new object[]
						{oTrans.EpiBaseForm, "SearchByDonor", true/* multi-select */, new DataTable() });
			// user cancelled
			if (ret == null) return;
			ArrayList list = (ArrayList)ret;
			//Return type is a calculated field, which is PackNum + ~ + VendorID
			//Handle Multiple Pack Slips
			for(int i = 0; i<list.Count; i++)
				string  pcPurPoint = string.Empty;
				string pcPackSlip = string.Empty;
				int piVendorNum = 0;
				string value = list[i].ToString();
				char delimiter = '~';
				string[] substrings = value.Split(delimiter);
				//set variables, first index is pack slip, second index is vendor num
				pcPackSlip = substrings[0];
				piVendorNum = Convert.ToInt32(substrings[1]);
				//Find PO Receipt Data by Donor Number as Pack Slip
				adapterReceipt = new ReceiptAdapter(oTrans);
				adapterReceipt.BOConnect();
				var adapterInsp = ((InspProcessingAdapter)(this.csm.TransAdaptersHT["oTrans_inspAdapter"]));
				//call a get by ID method and return all dtl within a specific pack slip
				bool result = adapterReceipt.GetByID(piVendorNum, "", pcPackSlip);
				if(result)
					//Find RcvDtl records that haven't been received yet (InspectionPending = false)
					//create list to store InspectionPending records line numbers
					List<int> inspPending = new List<int>();
					//Find RcvDtl records that haven't been received yet (InspectionPending = true)
					int index = 0;
					foreach(DataRow row in adapterReceipt.ReceiptData.RcvDtl)
						if(adapterReceipt.ReceiptData.RcvDtl[index].InspectionPending)
							inspPending.Add(adapterReceipt.ReceiptData.RcvDtl[index].PackLine);
						index++;
					//if no records waiting to be inspected, exit method
					if(inspPending.Count==0)
						MessageBox.Show(string.Format("Pack {0} has no Inspection Pending Receipt Detail records.", pcPackSlip));
						return;
//					foreach(int r in inspPending)
//						MessageBox.Show(r.ToString());
					//copy list to array for easy index crawling
					int piPackLine = 0;
					int[] array = new int[inspPending.Count];
					inspPending.CopyTo(array);
					foreach(int line in array)
						piPackLine = line;
						adapterInsp.GetReceiptByID(piVendorNum, "",pcPackSlip,piPackLine);
						oTrans.NotifyAll();
//					foreach(DataRow row in adapterReceipt.ReceiptData.RcvDtl)
//						//loop thru receipt detail records
//						if(inspPending.Contains(adapterReceipt.ReceiptData.RcvDtl[index].PackLine))
//						adapterInsp.GetReceiptByID(piVendorNum, "",pcPackSlip,piPackLine);
//						oTrans.NotifyAll();
//						piPackLine++;
					oTrans.NotifyAll();
					oTrans.NotifyAll(EpiTransaction.NotifyType.Initialize, edvporView);
					Erp.UI.Controls.Combos.InspectrCombo cmb = (Erp.UI.Controls.Combos.InspectrCombo)csm.GetNativeControlReference("fd9fe6a9-c62e-4a1e-86cf-57f55bb73815");
					cmb.Focus();
				else
					MessageBox.Show("Unable to find Pack Slip...");
				adapterReceipt.Dispose();
	private void InspectionProcessingEntryForm_Load(object sender, EventArgs args)
		// Add Event Handler Code
		InspectionProcessingEntryForm.StartPosition = FormStartPosition.CenterScreen;
		AddCustomTool();
Thanks Aaron!
