BAQ Parameters OR OData $filter
Hello folks!
From the REST API, does anyone know if it’s more efficient to call a BAQ with parameters or call a non-paramterized BAQ using the oData $filter query option?
Thanks!
I think it depends on how the BAQ is structured.
I think the where (filter) clauses are passed down to the BAQ call itself and combined, but that won’t always be helpful.
In cases where the full return data will contain so many rows that storing the data in memory will cause slowdowns, or when excluding the where clause / parameters will cause the query execution time to be noticeably longer, I would use the parameters. Otherwise I would use the $filter.
I think this sounds like what I wanted to know … the parameters operate IN the query on the DB side, and the OData $fllter is post data processing before delivery. Sound about right?
Basically if I want to be a good database citizen (as a cloud customer), I should go the parameterized route (if possible).
