Plantwhse table is what I was missing scanned by that one and thought
doesn't say part in the name probably not something I'm interested in.. go
figure I should have known better. Works like a charm now.
~Charlie
_____
Charles Carden
Sent: Tuesday, August 11, 2009 12:16 PM
Subject: Re: [Vantage] BAQ or Crystal that returns part info
Use the following:
Part to PartPlant using Company and PartNum as Links.
PartPlant to PlantWhse using Company, PartNum and WarehouseCode as Links.
PlantWhse to PartWhse Using Company, PartNum and Warehouse Code As links.
PartWhse to PartBin Using Company, PartNum, Warehouse Code As Links.
You could skip the PlantWhse to PartWhse and go from PlantWhse straight to
the PartBin unless you need information from the PartWhse record.
This will give you one record for each PartBin Record within a specific
plant and warehouse.
This query will give results for on hand stock.
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
~Charlie
_____
Charles Carden
Use the following:
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
----- Original Message -----
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Sent: Tuesday, August 11, 2009 10:51 AM
Subject: RE: [Vantage] BAQ or Crystal that returns part info
I have tried to use the warehouse table and everything I seems to do give me
1 billion records or illegal cyclic link errors.
~Charlie
_____
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
Charlie Wilson
Sent: Tuesday, August 11, 2009 11:20 AM
Well I can't figure out how to link them all together correctly. They need
to be in a chain with each other but that doesn't seem to be working out me.
~Charlie
_____
Behalf Of
Jeff Stockard
Sent: Tuesday, August 11, 2009 11:17 AM
Does the PartPlant table work in your BAQ?
Jeff
Behalf Of
Charlie Wilson
Sent: Tuesday, August 11, 2009 11:06 AM
Subject: [Vantage] BAQ or Crystal that returns part info
I need a baq and or a crystal that returns part num, plant, warehouse, bin.
This wouldn't be a problem if I could group this out but the report needs to
be in the format of a line per bin per warehouse per plant per part. So if a
part was in 4 bins that were spilt between 3 warehouse that were split
between 2 plants the return would look like this:
Partnum Plant1 warehouse1 bin1
Partnum Plant1 warehouse2 bin2
Partnum plant2 warehouse3 bin3
Partnum plant2 warehouse3 bin4
Any help would be greatly appreciated.
The problem I'm having is that the partwhse table doesn't have a plant field
in it.
~Charlie
