I have found that once you set an authorized user for Territory then you must set all. So remove their User ID from their own record but leave the View All and see if that works. Otherwise, add them them as an authorized user on every territory.
I can see the tables were the territory restriction would apply but isnât that only set at the company level? Meaning, if the company level is false then those tables donât have security?
What I do not understand is that we do not have this behavior in our older Pilot system, yet if I grab the query from SQL Profiler and run it in both databases they both return the same dataset in SSMS???
Here is a copy of the query if you ever want to join run it and see what the user has access too or if you want to join it to the generated BAQ SQL to see how it would work. You can just replace the "@TerritoryLst " variable with the temp table â#TerritoryLstâ referenced below.
DECLARE @Company varchar(8) = ''
DECLARE @CurrentUserID varchar(50) = ''
IF OBJECT_ID('tempdb..#TerritoryLst') IS NOT NULL DROP TABLE #TerritoryLst;
with [_TerrCTE_SalesRep] as
select uc.Company as Company, sr.SalesRepCode, ISNull(sr.ViewAllTer,0) as ViewAllTer, (case when em.FeatureID is null then 0 else 1 end) as TrCrAllowed
from [Erp].[UserComp] uc
left join [Erp].[SaleAuth] sa on sa.Company = uc.Company and sa.DcdUserID = uc.DcdUserID
left join [Erp].[SalesRep] sr on sr.Company = uc.Company and sr.SalesRepCode = sa.SalesRepCode
left join [Ice].[SysCompany] sc on sc.Company = uc.Company
left join [Ice].[EnabledModule] em on em.InstallationID = sc.InstallationID and em.FeatureID = '00000003-9662-4B1D-AD67-8D90C3599092'
where
(uc.Company = @Company) and uc.DcdUserID = @CurrentUserID
select st.Company, st.TerritoryID -- CRM disabled
into #TerritoryLst
from [_TerrCTE_SalesRep]
inner join [Erp].[SalesTer] st on st.Company = [_TerrCTE_SalesRep].Company and st.Inactive = 0
where [_TerrCTE_SalesRep].TrCrAllowed = 0
union
select st1.Company, st1.TerritoryID -- CRM enabled and ViewAllTerr=1
inner join [Erp].[SalesTer] st1 on st1.Company = [_TerrCTE_SalesRep].Company and st1.Inactive = 0
where [_TerrCTE_SalesRep].ViewAllTer = 1 and [_TerrCTE_SalesRep].TrCrAllowed = 1
union
select st2.Company, st2.TerritoryID -- CRM enabled and no SaleAuth
inner join [Erp].[SalesTer] st2 on st2.Company = [_TerrCTE_SalesRep].Company and st2.Inactive = 0
where [_TerrCTE_SalesRep].TrCrAllowed = 1 and not exists(select top 1 1 from [Erp].[SaleAuth] sa2
where sa2.Company = [_TerrCTE_SalesRep].Company and sa2.DcdUserID = @CurrentUserID
and sa2.SalesRepCode = [_TerrCTE_SalesRep].SalesRepCode)
union
select strp.Company, strp.TerritoryID -- CRM enabled and ViewAllTerr=0 and territories assigned
inner join [Erp].[SalesTRP] strp on [_TerrCTE_SalesRep].ViewAllTer = 0
and [_TerrCTE_SalesRep].Company = strp.Company and [_TerrCTE_SalesRep].SalesRepCode = strp.SalesRepCode;
select * from #TerritoryLst
