BAQ is adding extra rows
Has anyones been seeing epicor adding additional row into BAQ,s since DEC 2023
The BAQ below only has 5 rows but when it runs put 23 extra rows into the results.
This all started sometime in DEC - is there a known bug out there that can cause this
See below result
Sorry should of said Columns
Looks like you saved layout for that grid, there is a bug for it.
Are you on prem or in the cloud?
Gov Cloud
report it then. I don’t know the way to fix it from client
Are all 23 of those columns either user defined (_c) or system-related(SysRow, …)?
Hi Mark,
They appear to be system generated – When I dump the data to excel they say they are undefined
Thanks for any help
Jeff
We are experiencing this as well in Kinetic clouds within both the web browser and smartclient. We are in the midst of our golive week so I’ve created a dashboard that opens BAQ using classic as there are no issues with classic.
Every baq we run in Kinetic UI it’s like it adds those field displays to the next one and so on. After running a few with a lot of fields it became unmanageable to reset the columns. Switching the UI to classic for BAQ was a life saver…my role is data integrity and uploading all of our data via DMT so having my BAQs working properly was a must. Because I didn’t even know what Epicor was 11 months ago, I don’t have the skill set built up yet to troubleshoot, had to go straight to a simple workaround and will readdress after golive week is behind me.
Hi Staci
How did you switch the UI to classic view – I am thinking that would be a good fix until Epicor can fix the issue
