Good afternoon and thank you in advance! I am fairly new to Epicor and I have built a function that checks a partNum to see if it has a revision, if it does not, it will create one, set the revision and give it a description. Now, it will work if I feed the function a single partNum. But I built a BAQ that shows me a full list of part numbers that do not have a revision. The client I am building this for, would like me to be able to run the function and all the part numbers in the list will be checked and dealt with accordingly.
What I really need help with is the C# code that handles bringing in my BAQ. I can provide my code if necessary, but considering the part that I have works, I didn’t feel it necessary.
I can modify my function to use the data returned from the BAQ if I could get some help getting said data into my function.
Thank you again!
klincecum
(Kevin Lincecum)
April 16, 2024, 8:56pm
2
Add Service Ice->BO->DynamicQuery to references for your library.
string baqName = "Woot";
string paramID = "Yo";
CallService<DynamicQuerySvcContract>(dq =>
//if you need paramters
//Ice.Tablesets.QueryExecutionTableset qets = dq.GetQueryExecutionParametersByID(baqName);
// var qParam = qets.ExecutionParameter.Where(p => p.ParameterID == paramID).FirstOrDefault();
// qParam.ParameterValue = "I am a smoking monkey in a yellow hat";
//if you do not need paramters
Ice.Tablesets.QueryExecutionTableset qets = new Ice.Tablesets.QueryExecutionTableset();
DataSet ds = dq.ExecuteByID(baqName, qets);
Banderson
(Brandon Anderson)
April 16, 2024, 9:01pm
3
My personal preference is usually to do the work actually right in the BAQ, and make it a UBAQ. You can call the BAQ with parameters, and then in the post processing get list (always happens) or a custom action (which you’ll have to fire yourself), I do the work. I do this because if I need the data anyways, it’s right there in the BAQ and available to you in the BPM engine attached to the BAQ. Then you don’t have to do the work in the function. You can still call the BAQ from the function to do things, but I find the data set easier to work with.
Both ways are valid, one just seems easier to me.
Hally
(Simon Hall)
April 16, 2024, 11:44pm
4
As always there is no one correct answer
I built a function (with some help that will execute a given BAQ and will accept the BAQ name and a delimited string of the parameter pairs. This can be called from any function, and will accept any BAQ with any number of parameters and return the results… That’s the theory anyway.
You can call it from another function a bpm etc.
For the most part it works, but the using a colon as the pair separator is a bit of concern.
//Request params
//ParamList System.String
//BAQName System.String
//output params
//dsRestult System.Data.Dataset
//output System.String
//Helper Function (Func<T>) to get THIS Function ID https://www.epiusers.help/t/get-the-name-of-a-function/112406/4 Thanks Kev :)
Func<string> GetFunctionID = () =>
string functionName = this.GetType().Name;
string suffix = "Impl";
return functionName.EndsWith(suffix) ? functionName.Remove(functionName.LastIndexOf(suffix)) : functionName;
try
this.CallService<Ice.Contracts.DynamicQuerySvcContract>(BAQSvc => {
var ds = BAQSvc.GetByID(BAQName);
var dqds = BAQSvc.GetQueryExecutionParametersByID(BAQName);
//Split the parameter list into pairs and update the parameter values
if (this.ParamList != null && dqds.ExecutionParameter.Count > 0)
var paramPairs = this.ParamList.Split('~');
foreach (var pair in paramPairs)
var parts = pair.Split(':');
if (parts.Length == 2)
var paramName = parts[0];
var paramValue = parts[1];
var param = dqds.ExecutionParameter.Where(x => x.ParameterID == paramName).FirstOrDefault();
if (param != null)
param.ParameterValue = paramValue.ToString();
param.RowMod = "U";
else
//Yikes we have a problem Houston
output = $"BAQ ID-{BAQName} : No parameters were passed to the BAQ Service or the BAQ Service does not have any parameters.";
return;
//execute the BAQ
this.dsResult = BAQSvc.ExecuteByID(BAQName, dqds);
catch (Exception ex)
// Handle the exception here
string errMsg = $"{GetFunctionID()} ExecuteBAQ {BAQName}: An error occurred: {ex.Message}";
Ice.Diagnostics.Log.WriteEntry(errMsg);
throw new BLException(errMsg);
klincecum
(Kevin Lincecum)
April 17, 2024, 12:48am
5
Got an update for ya (of course that one works fine lol)
Looky Looky whats built in but not exposed:
string FunctionID = (string)this.GetType().GetProperty("FunctionID", System.Reflection.BindingFlags.Instance | System.Reflection.BindingFlags.NonPublic).GetGetMethod(nonPublic: true).Invoke(this, null);
Edit, gonna have to make an Epicor Idea for them to expose that.
Pain in the ass for logging.
Hally
(Simon Hall)
April 17, 2024, 12:51am
6
And of course I am looking at something else and I see that @kve already built something pretty similar and better…https://www.epiusers.help/t/helper-function-library-to-get-data-from-baqs-excel-files/110864
klincecum
(Kevin Lincecum)
April 17, 2024, 12:52am
7
We do that all the time here.
kve
(Kevin Veldman)
April 17, 2024, 1:31am
8
while ( Wheel.Exists )
thisLib.InventTheWheel();
IMHO, I believe in building small tools that do one thing really well and combining them to do something useful. I would create a function that ONLY creates the location. Personally, I would turn to PowerShell, which is made to combine tools. The first would run that runs a BAQ into a Custom Object and I would pipe that into the call to the function that creates the locations. I would not try to do all of this in one function myself.
I am unsure how to use what is in my ds object. When I type ds"." and press ctrl plus space, i am not seeing what I had anticipated which was the fields in my baq.
kve
(Kevin Veldman)
April 17, 2024, 2:21pm
12
ds will be your BAQ results as type System.Data.DataSet.
You can loop through your BAQ rows with something like this:
foreach ( DataRow row in ds.Tables[0].Rows )
string partNum = (string)row["Part_PartNum"]; // Use the Field Identifier from the Display Columns in your BAQ designer
Nice! That was what I thought, but I was unsure of the syntax… Thank you so much! I am not ashamed to admit that I am still learning and this experience is helping me tremendously!
Ok!! My function is working well! I am able to add a revision to a part, and add a short rev description. Customer just added that he would like the revision marked Approved. I found the method that runs after I competed a trace, however a box pops that states that a ‘Description of Change’ is needed. I cannot find in the trace though where this is added. A colleague of mine says that I cannot automate this in my function and that this box should be able to be turned off in the part menu. I am ok with either option. Does anyone have any insight into this?
Thanks you!
<tracePacket>
<businessObject>Ice.Proxy.BO.UserTracingImpl</businessObject>
<methodName>GetNewOrGetByID</methodName>
<appServerUri>https://epicor2023.electri-cord.local/ERP11Test/</appServerUri>
<returnType>Ice.BO.UserTracingDataSet</returnType>
<localTime>4/17/2024 13:03:56:5814730 PM</localTime>
<threadID>1</threadID>
<correlationId>54711018-29c7-4561-a097-f54de6cd0ae0</correlationId>
<executionTime total="6" roundTrip="4" channel="0" bpm="0" bpmDataForm="0" other="2" />
<retries>0</retries>
<parameters>
<parameter name="UserID" type="System.String"><![CDATA[ComTec]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>Update</methodName>
<returnType>System.Void</returnType>
<localTime>4/17/2024 13:03:56:5934207 PM</localTime>
<correlationId>162d7a2a-34eb-48df-b8e8-e7cf84005037</correlationId>
<executionTime total="14" roundTrip="12" channel="0" bpm="0" bpmDataForm="0" other="2" />
<parameters>
<parameter name="ds" type="Ice.BO.UserTracingDataSet">
<UserTracingDataSet xmlns="http://www.epicor.com/Ice/300/BO/UserTracing/UserTracing">
<UserTracing>
<UserID>ComTec</UserID>
<AssemblyReflector>Off</AssemblyReflector>
<BitFlagViewWatcher>Off</BitFlagViewWatcher>
<Catch>0</Catch>
<CustomContext>Off</CustomContext>
<DataTrace>false</DataTrace>
<DataTraceCCDataSet>false</DataTraceCCDataSet>
<DataTraceFullDataSets>false</DataTraceFullDataSets>
<DataTraceIncludeServerTrace>false</DataTraceIncludeServerTrace>
<DataTraceReturnData>false</DataTraceReturnData>
<DataTraceDSChanges>false</DataTraceDSChanges>
<DeploymentLogging>Off</DeploymentLogging>
<DeregistrationException>Off</DeregistrationException>
<DialogException>Off</DialogException>
<FormLoad>Off</FormLoad>
<LogException>Off</LogException>
<NotifyAll>Off</NotifyAll>
<TransactionLoad>Off</TransactionLoad>
<DashboardException>Off</DashboardException>
<TraceHelp>Off</TraceHelp>
<UITraceLogDirectory>C:\Users\nable\AppData\Roaming\epicor\log</UITraceLogDirectory>
<UITraceLocationScheme>Default from Epicor.exe.config file</UITraceLocationScheme>
<SysRevID>3440575821</SysRevID>
<SysRowID>fc8b8d9f-14ec-429f-a4d0-e451c8e7631b</SysRowID>
<Kinetic>false</Kinetic>
<BitFlag>0</BitFlag>
<RowMod></RowMod>
</UserTracing>
</UserTracingDataSet>
</parameter>
<parameter name="CallContext" type="Ice.Bpm.Context.ContextDataSet">
<ContextDataSet xmlns="http://www.epicor.com/Ice/300/Bpm/Context">
<BpmData>
<SysRowID>fd1b562a-da40-4406-81dd-5459272815cd</SysRowID>
</BpmData>
</ContextDataSet>
</parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Ice.Proxy.BO.ReportMonitorImpl</businessObject>
<methodName>GetRowsKeepIdleTimeWithBallonInfo</methodName>
<returnType>Ice.BO.ReportMonitorDataSet</returnType>
<localTime>4/17/2024 13:03:58:6782253 PM</localTime>
<threadID>24</threadID>
<correlationId>a05900bd-4276-4cd6-91ef-a4444f9ff77c</correlationId>
<executionTime total="5" roundTrip="4" channel="0" bpm="0" bpmDataForm="0" other="1" />
<parameters>
<parameter name="whereClauseSysRptLst" type="System.String"><![CDATA[((PrintDriver='TEXT' AND (AutoAction='PRINT' OR AutoAction='PREVIEW')) OR (PrintDriver='CRYSTAL' AND (AutoAction='PRINT' OR AutoAction='AUTOPRT' OR AutoAction='PREVIEW' OR AutoAction='AUTOPRV' OR AutoAction='SSRSPREVIEW')) OR (PrintDriver='EPIFIN' AND (AutoAction='PRINT' OR AutoAction='PREVIEW')) OR (PrintDriver='BARTENDER' AND (AutoAction='AUTOPRT' OR AutoAction='AUTOPRV')) OR (PrintDriver='EDI' AND AutoAction<>'') OR (PrintDriver='SSRS' AND (AutoAction='PREVIEW' OR AutoAction='PRINT') AND LastAction='SSRSREADY')) AND (WorkStationID='EPICOR2023 6' OR WorkStationID='web_ComTec')]]></parameter>
<parameter name="getBallonInfo" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="whereClauseSysTask" type="System.String"><![CDATA[history = true and startedon > 04/16/2024 and SubmitUser = 'ComTec']]></parameter>
<parameter name="whereClauseSysTaskLog" type="System.String"><![CDATA[]]></parameter>
<parameter name="sysMonitorData" type="System.Data.DataSet">
<NewDataSet />
</parameter>
<BpmData>
<SysRowID>00000000-0000-0000-0000-000000000000</SysRowID>
</BpmData>
</ContextDataSet>
</parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Erp.Proxy.BO.PartImpl</businessObject>
<methodName>PromptForPassword</methodName>
<localTime>4/17/2024 13:04:03:6463132 PM</localTime>
<correlationId>2b4a058f-a17c-4876-8934-26f8969022e4</correlationId>
<executionTime total="9" roundTrip="7" channel="0" bpm="0" bpmDataForm="0" other="2" />
<parameters>
<BpmData>
</BpmData>
</ContextDataSet>
</parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>ChangePartRevApproved</methodName>
<localTime>4/17/2024 13:04:03:6562696 PM</localTime>
<correlationId>d40a15b3-a407-4b02-905e-5ba6da1b59f8</correlationId>
<executionTime total="21" roundTrip="18" channel="0" bpm="0" bpmDataForm="0" other="3" />
<parameters>
<parameter name="ipApproved" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="ipValidPassword" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="ds" type="Erp.BO.PartDataSet">
<PartDataSet xmlns="http://www.epicor.com/Ice/300/BO/Part/Part">
<Part>
<Company>ECM</Company>
<PartNum>10.1761</PartNum>
<SearchWord>1/0 AWG</SearchWord>
<PartDescription>1/0 AWG WELDING CABLE ANIXTER 5J-1011</PartDescription>
<ClassID>WIRE</ClassID>
<IUM>FT</IUM>
<PUM>FT</PUM>
<TypeCode>P</TypeCode>
<NonStock>false</NonStock>
<PurchasingFactor>1.0000</PurchasingFactor>
<UnitPrice>0.00000</UnitPrice>
<PricePerCode>E</PricePerCode>
<InternalUnitPrice>0.00000</InternalUnitPrice>
<InternalPricePerCode>E</InternalPricePerCode>
<ProdCode>OTHER</ProdCode>
<MfgComment></MfgComment>
<PurComment></PurComment>
<CostMethod>S</CostMethod>
<UserChar1></UserChar1>
<UserChar2></UserChar2>
<UserChar3></UserChar3>
<UserChar4></UserChar4>
<UserDecimal1>0.00</UserDecimal1>
<UserDecimal2>0.00</UserDecimal2>
<UserDecimal3>0.00000</UserDecimal3>
<UserDecimal4>0.00000</UserDecimal4>
<UserInteger1>0</UserInteger1>
<UserInteger2>0</UserInteger2>
<TaxCatID></TaxCatID>
<InActive>false</InActive>
<LowLevelCode>0</LowLevelCode>
<Method>false</Method>
<TrackLots>false</TrackLots>
<TrackDimension>false</TrackDimension>
<DefaultDim></DefaultDim>
<TrackSerialNum>false</TrackSerialNum>
<CommodityCode></CommodityCode>
<WarrantyCode></WarrantyCode>
<PhantomBOM>false</PhantomBOM>
<SalesUM>FT</SalesUM>
<SellingFactor>1.00000000</SellingFactor>
<MtlBurRate>0.00000</MtlBurRate>
<NetWeight>0.00000</NetWeight>
<UsePartRev>true</UsePartRev>
<PartsPerContainer>0</PartsPerContainer>
<PartLength>0.00000</PartLength>
<PartWidth>0.00000</PartWidth>
<PartHeight>0.00000</PartHeight>
<LotShelfLife>0</LotShelfLife>
<WebPart>false</WebPart>
<RunOut>false</RunOut>
<SubPart></SubPart>
<Diameter>0.00000</Diameter>
<Gravity>0.00000</Gravity>
<OnHold>false</OnHold>
<OnHoldReasonCode></OnHoldReasonCode>
<AnalysisCode></AnalysisCode>
<GlobalPart>true</GlobalPart>
<MtlAnalysisCode></MtlAnalysisCode>
<GlobalLock>false</GlobalLock>
<ISSuppUnitsFactor>1.00000000</ISSuppUnitsFactor>
<PDMObjID></PDMObjID>
<ImageFileName></ImageFileName>
<ISOrigCountry>0</ISOrigCountry>
<SNPrefix></SNPrefix>
<SNFormat></SNFormat>
<SNBaseDataType></SNBaseDataType>
<Constrained>true</Constrained>
<UPCCode1></UPCCode1>
<UPCCode2></UPCCode2>
<UPCCode3></UPCCode3>
<EDICode></EDICode>
<WebInStock>false</WebInStock>
<ConsolidatedPurchasing>false</ConsolidatedPurchasing>
<PurchasingFactorDirection>D</PurchasingFactorDirection>
<SellingFactorDirection>D</SellingFactorDirection>
<RecDocReq>false</RecDocReq>
<MDPV>0</MDPV>
<ShipDocReq>false</ShipDocReq>
<ReturnableContainer></ReturnableContainer>
<NetVolume>0.00000</NetVolume>
<QtyBearing>true</QtyBearing>
<NAFTAOrigCountry></NAFTAOrigCountry>
<NAFTAProd></NAFTAProd>
<NAFTAPref></NAFTAPref>
<ExpLicType></ExpLicType>
<ExpLicNumber></ExpLicNumber>
<ECCNNumber></ECCNNumber>
<AESExp></AESExp>
<HTS></HTS>
<UseHTSDesc>false</UseHTSDesc>
<SchedBcode></SchedBcode>
<HazItem>false</HazItem>
<HazTechName></HazTechName>
<HazClass></HazClass>
<HazSub></HazSub>
<HazGvrnmtID></HazGvrnmtID>
<HazPackInstr></HazPackInstr>
<RevChargeMethod></RevChargeMethod>
<RCUnderThreshold>0.000</RCUnderThreshold>
<RCOverThreshold>0.000</RCOverThreshold>
<OwnershipStatus></OwnershipStatus>
<UOMClassID>LENGTH</UOMClassID>
<SNMask></SNMask>
<SNMaskExample></SNMaskExample>
<SNMaskSuffix></SNMaskSuffix>
<SNMaskPrefix></SNMaskPrefix>
<SNLastUsedSeq></SNLastUsedSeq>
<UseMaskSeq>false</UseMaskSeq>
<NetWeightUOM>OZ</NetWeightUOM>
<NetVolumeUOM>FZ</NetVolumeUOM>
<LotBatch>false</LotBatch>
<LotMfgBatch>false</LotMfgBatch>
<LotMfgLot>false</LotMfgLot>
<LotHeat>false</LotHeat>
<LotFirmware>false</LotFirmware>
<LotBeforeDt>false</LotBeforeDt>
<LotMfgDt>false</LotMfgDt>
<LotCureDt>false</LotCureDt>
<LotExpDt>false</LotExpDt>
<LotPrefix></LotPrefix>
<LotUseGlobalSeq>false</LotUseGlobalSeq>
<LotSeqID></LotSeqID>
<LotNxtNum>1</LotNxtNum>
<LotDigits>0</LotDigits>
<LotLeadingZeros>false</LotLeadingZeros>
<LotAppendDate></LotAppendDate>
<BuyToOrder>false</BuyToOrder>
<DropShip>false</DropShip>
<IsConfigured>false</IsConfigured>
<ExtConfig>false</ExtConfig>
<RefCategory></RefCategory>
<CSFCJ5>false</CSFCJ5>
<CSFLMW>false</CSFLMW>
<GrossWeight>0.00000</GrossWeight>
<GrossWeightUOM>OZ</GrossWeightUOM>
<BasePartNum></BasePartNum>
<FSAssetClassCode></FSAssetClassCode>
<FSSalesUnitPrice>0.00000</FSSalesUnitPrice>
<FSPricePerCode>E</FSPricePerCode>
<RcvInspectionReq>false</RcvInspectionReq>
<EstimateID></EstimateID>
<EstimateOrPlan></EstimateOrPlan>
<DiffPrc2PrchUOM>false</DiffPrc2PrchUOM>
<DupOnJobCrt>false</DupOnJobCrt>
<PricingFactor>0.00000</PricingFactor>
<PricingUOM></PricingUOM>
<MobilePart>true</MobilePart>
<SysRevID>595291056</SysRevID>
<SysRowID>f300f95b-4bca-1d81-e211-07ef40ef2798</SysRowID>
<AGUseGoodMark>false</AGUseGoodMark>
<AGProductMark>false</AGProductMark>
<ISRegion></ISRegion>
<INChapterID></INChapterID>
<PESUNATType></PESUNATType>
<PESUNATUOM></PESUNATUOM>
<DEIsServices>false</DEIsServices>
<DEIsSecurityFinancialDerivative>false</DEIsSecurityFinancialDerivative>
<DEInternationalSecuritiesID></DEInternationalSecuritiesID>
<LinkToContract>false</LinkToContract>
<DEIsInvestment>false</DEIsInvestment>
<DEPayStatCode>0</DEPayStatCode>
<DEDenomination></DEDenomination>
<PartLengthWidthHeightUM></PartLengthWidthHeightUM>
<DiameterUM></DiameterUM>
<DiameterInside>0.00000</DiameterInside>
<DiameterOutside>0.00000</DiameterOutside>
<ThicknessUM></ThicknessUM>
<Thickness>0.00000</Thickness>
<ThicknessMax>0.00000</ThicknessMax>
<Durometer></Durometer>
<Specification></Specification>
<EngineeringAlert></EngineeringAlert>
<Condition></Condition>
<IsCompliant>false</IsCompliant>
<IsRestricted>false</IsRestricted>
<IsSafetyItem>false</IsSafetyItem>
<CommercialBrand></CommercialBrand>
<CommercialSubBrand></CommercialSubBrand>
<CommercialCategory></CommercialCategory>
<CommercialSubCategory></CommercialSubCategory>
<CommercialStyle></CommercialStyle>
<CommercialSize1></CommercialSize1>
<CommercialSize2></CommercialSize2>
<CommercialColor></CommercialColor>
<IsGiftCard>false</IsGiftCard>
<PhotoFile></PhotoFile>
<PartPhotoExists>false</PartPhotoExists>
<CommentText></CommentText>
<PartSpecificPackingUOM>false</PartSpecificPackingUOM>
<ImageID></ImageID>
<CNSpecification></CNSpecification>
<SyncToExternalCRM>false</SyncToExternalCRM>
<ExternalCRMPartID></ExternalCRMPartID>
<ExternalCRMSyncRequired>false</ExternalCRMSyncRequired>
<PESUNATTypeCode></PESUNATTypeCode>
<PESUNATUOMCode></PESUNATUOMCode>
<CNCodeVersion></CNCodeVersion>
<CNTaxCategoryCode></CNTaxCategoryCode>
<CNHasPreferentialTreatment>false</CNHasPreferentialTreatment>
<CNPreferentialTreatmentContent></CNPreferentialTreatmentContent>
<CNZeroTaxRateMark></CNZeroTaxRateMark>
<SubLevelCode>0</SubLevelCode>
<CreatedBy></CreatedBy>
<AttBatch>N</AttBatch>
<AttMfgBatch>N</AttMfgBatch>
<AttMfgLot>N</AttMfgLot>
<AttHeat>N</AttHeat>
<AttFirmware>N</AttFirmware>
<AttBeforeDt>N</AttBeforeDt>
<AttMfgDt>N</AttMfgDt>
<AttCureDt>N</AttCureDt>
<AttExpDt>N</AttExpDt>
<DeferManualEntry>false</DeferManualEntry>
<DeferPurchaseReceipt>false</DeferPurchaseReceipt>
<DeferJobReceipt>false</DeferJobReceipt>
<DeferInspection>false</DeferInspection>
<DeferQtyAdjustment>false</DeferQtyAdjustment>
<DeferInventoryMove>false</DeferInventoryMove>
<DeferShipments>false</DeferShipments>
<DeferInventoryCounts>false</DeferInventoryCounts>
<DeferAssetDisposal>false</DeferAssetDisposal>
<DeferReturnMaterials>false</DeferReturnMaterials>
<MXProdServCode></MXProdServCode>
<MXCustomsDuty></MXCustomsDuty>
<SendToFSA>false</SendToFSA>
<ExternalMESSyncRequired>false</ExternalMESSyncRequired>
<FSAItem>false</FSAItem>
<FSAEquipment>false</FSAEquipment>
<BOLClass></BOLClass>
<FairMarketValue>0.00000</FairMarketValue>
<SAFTProdCategory></SAFTProdCategory>
<AttrClassID></AttrClassID>
<LocationIDNumReq>false</LocationIDNumReq>
<LocationTrackInv>false</LocationTrackInv>
<LocationMtlView>false</LocationMtlView>
<LCNRVReporting>false</LCNRVReporting>
<LCNRVEstimatedUnitPrice>0.000</LCNRVEstimatedUnitPrice>
<MXCustomsUMFrom></MXCustomsUMFrom>
<LocationFormatID></LocationFormatID>
<IsServices>false</IsServices>
<PEDetrGoodServiceCode></PEDetrGoodServiceCode>
<PEProductServiceCode></PEProductServiceCode>
<DualUOMClassID></DualUOMClassID>
<CNProductName></CNProductName>
<CNWeight>0.00000</CNWeight>
<CNWeightUOM></CNWeightUOM>
<CNBonded>false</CNBonded>
<TrackInventoryAttributes>false</TrackInventoryAttributes>
<DefaultAttributeSetID>0</DefaultAttributeSetID>
<AttISOrigCountry>N</AttISOrigCountry>
<ExternalSchemeID></ExternalSchemeID>
<ExternalID></ExternalID>
<CommoditySchemeID></CommoditySchemeID>
<CommoditySchemeVersion></CommoditySchemeVersion>
<TrackInventoryByRevision>false</TrackInventoryByRevision>
<PlanningByRevision>false</PlanningByRevision>
<CountryNumDescription></CountryNumDescription>
<EnableExpressCheckOut>false</EnableExpressCheckOut>
<EnableGlobalLock>false</EnableGlobalLock>
<EnableGlobalPart>true</EnableGlobalPart>
<EnableInActive>true</EnableInActive>
<EnableIUM>false</EnableIUM>
<EnableRevCharge>false</EnableRevCharge>
<EnableSerialNum>false</EnableSerialNum>
<EnableTrackSerialNum>true</EnableTrackSerialNum>
<EnableUOMClass>false</EnableUOMClass>
<ExtCoExist>true</ExtCoExist>
<FSAInstallationCost>0.00000</FSAInstallationCost>
<FSAInstallationRequired>false</FSAInstallationRequired>
<FSAInstallationType></FSAInstallationType>
<FSAInstTypeDesc></FSAInstTypeDesc>
<GlbFlag>true</GlbFlag>
<GlbLink></GlbLink>
<GlbTableAllowUpdTrackDim>false</GlbTableAllowUpdTrackDim>
<GlbTableAllowUpdTrackLots>false</GlbTableAllowUpdTrackLots>
<GlbTableAllowUpdTrackSerial>false</GlbTableAllowUpdTrackSerial>
<HasOnHandQty>false</HasOnHandQty>
<IsComponent>false</IsComponent>
<IsCoPart>false</IsCoPart>
<ISOrigCountryNum>0</ISOrigCountryNum>
<NextGeneratedLotNum></NextGeneratedLotNum>
<PEDetrGoodServiceCodeDesc></PEDetrGoodServiceCodeDesc>
<PEProductServiceCodeDesc></PEProductServiceCodeDesc>
<PLM>false</PLM>
<PLMEnabled>false</PLMEnabled>
<Revision>false</Revision>
<SalesUMDisp>FT</SalesUMDisp>
<SNLeadingZeros>false</SNLeadingZeros>
<SNMaskPrefixLength>0</SNMaskPrefixLength>
<SNMaskSuffixLength>0</SNMaskSuffixLength>
<SNNumODigits>0</SNNumODigits>
<UpdatePartPlant>false</UpdatePartPlant>
<UpdateSNPartPlant>false</UpdateSNPartPlant>
<COASegReferences></COASegReferences>
<HasMRPPlanningAttribute>false</HasMRPPlanningAttribute>
<UpdatePartPlantOverride>false</UpdatePartPlantOverride>
<DEPayStatCodeDescr></DEPayStatCodeDescr>
<DEDenominationDescr></DEDenominationDescr>
<BitFlag>8</BitFlag>
<AnalysisCdDescription></AnalysisCdDescription>
<ClassDescription>WIRE</ClassDescription>
<CommodityCodeSuppUnitsUOM></CommodityCodeSuppUnitsUOM>
<CommodityCodeDescription></CommodityCodeDescription>
<CompanySendToFSA>false</CompanySendToFSA>
<DualUOMClassIDDescription></DualUOMClassIDDescription>
<DynAttrValueSetShortDescription></DynAttrValueSetShortDescription>
<DynAttrValueSetDescription></DynAttrValueSetDescription>
<FSAssetClassCodeFSAssetClassDesc></FSAssetClassCodeFSAssetClassDesc>
<Mtl_AnalysisCdDescription></Mtl_AnalysisCdDescription>
<MXProdServCodeDesc></MXProdServCodeDesc>
<OnHoldReasonCodeDescription></OnHoldReasonCodeDescription>
<ProdCodeDescription>OTHER</ProdCodeDescription>
<RefCategoryDescription></RefCategoryDescription>
<SerialMaskMaskType>0</SerialMaskMaskType>
<SerialMaskDescription></SerialMaskDescription>
<TaxCatIDDescription></TaxCatIDDescription>
<UOMClassIDDescription>LENGTH</UOMClassIDDescription>
<WarrantyCodeWarrDescription></WarrantyCodeWarrDescription>
<XbSystELIEinvoice>true</XbSystELIEinvoice>
<RowMod></RowMod>
<Character01></Character01>
<Character02></Character02>
<Character03></Character03>
<Character05></Character05>
<Number01>0.000000000</Number01>
<Number05>0.000000000</Number05>
<Number06>0.000000000</Number06>
<CheckBox01>true</CheckBox01>
<CheckBox02>false</CheckBox02>
<CheckBox03>false</CheckBox03>
<CheckBox05>false</CheckBox05>
<CheckBox06>false</CheckBox06>
<CheckBox07>false</CheckBox07>
<CheckBox08>false</CheckBox08>
<ShortChar01></ShortChar01>
<ShortChar02>Inspect</ShortChar02>
<ShortChar03></ShortChar03>
<ShortChar04></ShortChar04>
<ShortChar05></ShortChar05>
<ShortChar06></ShortChar06>
<ShortChar07></ShortChar07>
<ShortChar08></ShortChar08>
<ShortChar09></ShortChar09>
<ShortChar10></ShortChar10>
<CheckBox04>false</CheckBox04>
<MinSellQty_c>0.00</MinSellQty_c>
<Forecasted_c>false</Forecasted_c>
<ISO13485_c>false</ISO13485_c>
<TS_16949_c>false</TS_16949_c>
<CCN_c></CCN_c>
<ULListed_c>false</ULListed_c>
<ApprovedMargin_c>0.00</ApprovedMargin_c>
<TariffCustomer_c>0.00</TariffCustomer_c>
<TariffSupplier_c>0.00</TariffSupplier_c>
<Prop65_c>false</Prop65_c>
<Amortized_c>false</Amortized_c>
<Commission1_c>0.00000</Commission1_c>
<Commission2_c>0.00000</Commission2_c>
<DiscountPct_c>0.00000</DiscountPct_c>
<CopyExact_c>false</CopyExact_c>
<CSRMX_c></CSRMX_c>
<CSRUS_c></CSRUS_c>
<ASM3CELL_c>false</ASM3CELL_c>
<Engineer_c></Engineer_c>
<CopperWeight_c>0.00000</CopperWeight_c>
<UD_SysRevID>AAAAAAQS4V0=</UD_SysRevID>
</Part>
<PartPlant>
<Plant>MfgSys</Plant>
<PrimWhse>RAW</PrimWhse>
<MinimumQty>0.00000000</MinimumQty>
<MaximumQty>0.00000000</MaximumQty>
<SafetyQty>0.00000000</SafetyQty>
<MinOrderQty>1000.00000000</MinOrderQty>
<LeadTime>10</LeadTime>
<VendorNum>20</VendorNum>
<PurPoint>1</PurPoint>
<BackFlush>false</BackFlush>
<MfgLotSize>0.00</MfgLotSize>
<MinMfgLotSize>0.00</MinMfgLotSize>
<MaxMfgLotSize>0.00</MaxMfgLotSize>
<MfgLotMultiple>0.00</MfgLotMultiple>
<DaysOfSupply>30</DaysOfSupply>
<ReOrderLevel>false</ReOrderLevel>
<MRPRecalcNeeded>false</MRPRecalcNeeded>
<ProcessMRP>true</ProcessMRP>
<GenerateSugg>true</GenerateSugg>
<GetFromLocalWhse>false</GetFromLocalWhse>
<ForecastTime>0</ForecastTime>
<TransferPlant></TransferPlant>
<SourceType>P</SourceType>
<TransferLeadTime>0</TransferLeadTime>
<PrepTime>0</PrepTime>
<ReceiveTime>0</ReceiveTime>
<PlanTimeFence>0</PlanTimeFence>
<ReschedOutDelta>0</ReschedOutDelta>
<ReschedInDelta>0</ReschedInDelta>
<BuyerID></BuyerID>
<PersonID></PersonID>
<AltMethod></AltMethod>
<KitTime>0</KitTime>
<KitAllowUpdate>false</KitAllowUpdate>
<KitShipComplete>true</KitShipComplete>
<KitAllowChangeParms>false</KitAllowChangeParms>
<KitBackFlush>false</KitBackFlush>
<KitPricing>P</KitPricing>
<KitPrintCompsPS>true</KitPrintCompsPS>
<KitPrintCompsInv>true</KitPrintCompsInv>
<ShortHorizonDays>0</ShortHorizonDays>
<ShortHorizonMinMfgLotSize>0.00</ShortHorizonMinMfgLotSize>
<ShortHorizonMaxMfgLotSize>0.00</ShortHorizonMaxMfgLotSize>
<LimitProdYldRecalc>false</LimitProdYldRecalc>
<MRPLastRunDate>2024-03-06T00:00:00-05:00</MRPLastRunDate>
<MRPLastRunTime>36930</MRPLastRunTime>
<MRPLastScheduledDate>2024-01-02T00:00:00-05:00</MRPLastScheduledDate>
<ShortHorizonDaysSupp>0</ShortHorizonDaysSupp>
<SNMask></SNMask>
<PcntTolerance>0.00</PcntTolerance>
<CalcPcnt>false</CalcPcnt>
<CalcQty>false</CalcQty>
<CalcValue>false</CalcValue>
<QtyAdjTolerance>0.00000000</QtyAdjTolerance>
<QtyTolerance>0</QtyTolerance>
<ValueTolerance>0</ValueTolerance>
<DemandQty>0.00000000</DemandQty>
<ReservedQty>0.00000000</ReservedQty>
<AllocatedQty>0.00000000</AllocatedQty>
<XRefPartNum></XRefPartNum>
<XRefPartType></XRefPartType>
<NeverReuseMRPJob>false</NeverReuseMRPJob>
<DeleteMRPJobs>false</DeleteMRPJobs>
<TotMfgLeadTimeSys>0</TotMfgLeadTimeSys>
<TotMfgLeadTimeMnl>0</TotMfgLeadTimeMnl>
<LvlMfgLeadTimeSys>0</LvlMfgLeadTimeSys>
<LvlMfgLeadTimeMnl>0</LvlMfgLeadTimeMnl>
<AutoConsumeStock>false</AutoConsumeStock>
<StartMinLotQty>false</StartMinLotQty>
<MinLotLeadTime>0</MinLotLeadTime>
<MfgLeadTimeMnl>false</MfgLeadTimeMnl>
<MfgLeadTimeEnteredBy></MfgLeadTimeEnteredBy>
<MinStartQty>0.00000000</MinStartQty>
<RawMaterial>false</RawMaterial>
<MultiLevelCTP>false</MultiLevelCTP>
<ConsumeSafety>false</ConsumeSafety>
<SLTVendorNum>0</SLTVendorNum>
<SLTPurPoint></SLTPurPoint>
<ShortLeadTime>0</ShortLeadTime>
<ExternalMES>false</ExternalMES>
<SysRevID>3440777672</SysRevID>
<SysRowID>f300f95b-4bca-1d81-e211-07ef50602a98</SysRowID>
<UrgentLeadTime>0</UrgentLeadTime>
<UrgentMinOrdQty>0.00000000</UrgentMinOrdQty>
<UrgentMultQty>0.00</UrgentMultQty>
<UrgentPurPoint></UrgentPurPoint>
<UrgentVendorNum>0</UrgentVendorNum>
<PartRunMRP>false</PartRunMRP>
<MMSExclude>false</MMSExclude>
<MMSSales>false</MMSSales>
<MMSIssue>false</MMSIssue>
<MMSHistory>0</MMSHistory>
<MMSSafetyFactor>0</MMSSafetyFactor>
<MMSMaxFactor>0.00</MMSMaxFactor>
<SavedMinimumQty>0.00000000</SavedMinimumQty>
<SavedMaximumQty>0.00000000</SavedMaximumQty>
<SavedSafetyQty>0.00000000</SavedSafetyQty>
<SavedCalculatedUsageQty>0.00000000</SavedCalculatedUsageQty>
<ACWPercentage>0</ACWPercentage>
<ACWDays>0</ACWDays>
<GenNewPCIDDelaySeconds>0</GenNewPCIDDelaySeconds>
<GenNewPCIDLimitDays>0</GenNewPCIDLimitDays>
<TopLvlMfgLeadTimeSys>0</TopLvlMfgLeadTimeSys>
<TopLvlMfgLeadTimeMnl>0</TopLvlMfgLeadTimeMnl>
<ActualCostingCategoryID></ActualCostingCategoryID>
<IncludedIntoAllocationBase>false</IncludedIntoAllocationBase>
<ForecastDaysBefore>0</ForecastDaysBefore>
<ForecastDaysAfter>0</ForecastDaysAfter>
<BaseUOMCode>FT</BaseUOMCode>
<CalculatedLeadTime>10</CalculatedLeadTime>
<ExtLeadTime>0</ExtLeadTime>
<UrgentVendorName></UrgentVendorName>
<UrgentVendorVendorID></UrgentVendorVendorID>
<DisableQtyBrng>false</DisableQtyBrng>
<ICTrader>false</ICTrader>
<OnHandQty>0</OnHandQty>
<PlantConfCtrlSerialTracking>1</PlantConfCtrlSerialTracking>
<IsActCostingAllocEnabled>false</IsActCostingAllocEnabled>
<MaximumQtyNofP>0.00000000</MaximumQtyNofP>
<MaxMfgLotSizeNofP>0.00000000</MaxMfgLotSizeNofP>
<MfgLotMultipleNofP>0.00000000</MfgLotMultipleNofP>
<MinimumQtyNofP>0.00000000</MinimumQtyNofP>
<MinMfgLotSizeNofP>0.00000000</MinMfgLotSizeNofP>
<MinOrderQtyNofP>0.00000000</MinOrderQtyNofP>
<MinStartQtyNofP>0.00000000</MinStartQtyNofP>
<QtyDisplayOption></QtyDisplayOption>
<SafetyQtyNofP>0.00000000</SafetyQtyNofP>
<ShortHorizonMaxMfgLotSizeNofP>0.00000000</ShortHorizonMaxMfgLotSizeNofP>
<ShortHorizonMinMfgLotSizeNofP>0.00000000</ShortHorizonMinMfgLotSizeNofP>
<UrgentMinOrdQtyNofP>0.00000000</UrgentMinOrdQtyNofP>
<UrgentMultQtyNofP>0.00000000</UrgentMultQtyNofP>
<BuyerIDName></BuyerIDName>
<PartTrackInventoryAttributes>false</PartTrackInventoryAttributes>
<PartAttrClassID></PartAttrClassID>
<PartSellingFactor>1.00000000</PartSellingFactor>
<PartTrackLots>false</PartTrackLots>
<PartTrackSerialNum>false</PartTrackSerialNum>
<PartTrackDimension>false</PartTrackDimension>
<PartIUM>FT</PartIUM>
<PartPricePerCode>E</PartPricePerCode>
<PartPartDescription>1/0 AWG WELDING CABLE ANIXTER 5J-1011</PartPartDescription>
<PartSalesUM>FT</PartSalesUM>
<PersonName></PersonName>
<PlantName>ELECTRI-CORD MFG - PA PLANT</PlantName>
<PrimWhseDescription>RAW MATERIAL</PrimWhseDescription>
<TransferPlantName></TransferPlantName>
<VendorNumAddress1>PO BOX 26157</VendorNumAddress1>
<VendorNumState>PA</VendorNumState>
<VendorNumCountry>UNITED STATES</VendorNumCountry>
<VendorNumCity>COLLEGEVILLE</VendorNumCity>
<VendorNumCurrencyCode>BASE</VendorNumCurrencyCode>
<VendorNumDefaultFOB>FOBSHIP</VendorNumDefaultFOB>
<VendorNumAddress2></VendorNumAddress2>
<VendorNumZIP>26157</VendorNumZIP>
<VendorNumTermsCode>N60</VendorNumTermsCode>
<VendorNumAddress3></VendorNumAddress3>
<VendorNumName>ALLIED WIRE & CABLE</VendorNumName>
<VendorNumVendorID>1018</VendorNumVendorID>
<RowMod></RowMod>
<Character04></Character04>
<Character06></Character06>
<CheckBox01>false</CheckBox01>
<ToolingCap_c>0.00</ToolingCap_c>
<UD_SysRevID>AAAAAAQMCfI=</UD_SysRevID>
</PartPlant>
<PartRev>
<RevisionNum>-</RevisionNum>
<RevShortDesc>Default</RevShortDesc>
<RevDescription></RevDescription>
<Approved>true</Approved>
<ApprovedBy></ApprovedBy>
<EffectiveDate>2024-04-17T00:00:00-04:00</EffectiveDate>
<TLRLaborCost>0.00000</TLRLaborCost>
<TLRBurdenCost>0.00000</TLRBurdenCost>
<TLRMaterialCost>0.00000</TLRMaterialCost>
<TLRSubcontractCost>0.00000</TLRSubcontractCost>
<TLRMtlBurCost>0.00000</TLRMtlBurCost>
<TLRSetupLaborCost>0.00000</TLRSetupLaborCost>
<TLRSetupBurdenCost>0.00000</TLRSetupBurdenCost>
<LLRLaborCost>0.00000</LLRLaborCost>
<LLRBurdenCost>0.00000</LLRBurdenCost>
<LLRMaterialCost>0.00000</LLRMaterialCost>
<LLRSubcontractCost>0.00000</LLRSubcontractCost>
<LLRMtlBurCost>0.00000</LLRMtlBurCost>
<LLRSetupLaborCost>0.00000</LLRSetupLaborCost>
<LLRSetupBurdenCost>0.00000</LLRSetupBurdenCost>
<DrawNum></DrawNum>
<ECO></ECO>
<AutoRecOpr>0</AutoRecOpr>
<FinalOpr>0</FinalOpr>
<Configured>false</Configured>
<WebConfigured>false</WebConfigured>
<ShowInputPrice>false</ShowInputPrice>
<AltMethodDesc></AltMethodDesc>
<Plant>MN</Plant>
<ParentAltMethod></ParentAltMethod>
<UseStaging>false</UseStaging>
<UseAltRevForParts>false</UseAltRevForParts>
<ValRefDes>false</ValRefDes>
<PcGlobalPart>false</PcGlobalPart>
<PcEntprsConf>false</PcEntprsConf>
<GlobalRev>false</GlobalRev>
<RoughCutCode></RoughCutCode>
<RMAInspPlan></RMAInspPlan>
<RMASpecID></RMASpecID>
<RMASampleSize>0.00000000</RMASampleSize>
<RMASampleSizePct>0.00</RMASampleSizePct>
<BaseRevisionNum></BaseRevisionNum>
<ConfigID></ConfigID>
<RegenConfig>false</RegenConfig>
<SIValuesGroupSeq>0</SIValuesGroupSeq>
<SIValuesHeadNum>0</SIValuesHeadNum>
<SysRevID>3441156476</SysRevID>
<SysRowID>cf469999-a5fa-4667-a855-083e04d9fbc3</SysRowID>
<ProcessMode>S</ProcessMode>
<DefaultConfigPart>false</DefaultConfigPart>
<CoPartsReqQty>0.00000000</CoPartsReqQty>
<MtlCostPct>0.00000</MtlCostPct>
<LaborCostPct>0.00000</LaborCostPct>
<CoPartsPerOp>0</CoPartsPerOp>
<CreatedBy>ComTec</CreatedBy>
<CreatedOn>2024-04-17T16:55:30.773-04:00</CreatedOn>
<ChangedBy>ComTec</ChangedBy>
<ChangedOn>2024-04-17T16:55:30.773-04:00</ChangedOn>
<CNCustomsBOM>false</CNCustomsBOM>
<ProcessMfgID></ProcessMfgID>
<ProcessMfgType></ProcessMfgType>
<ProcessMfgDescription></ProcessMfgDescription>
<UseAdvancedStaging>false</UseAdvancedStaging>
<ProcessMfgLastGroupID></ProcessMfgLastGroupID>
<DisableApproved>false</DisableApproved>
<ECOGroup></ECOGroup>
<HasCoParts>false</HasCoParts>
<ParentAltMethodDesc></ParentAltMethodDesc>
<ParentPartNum></ParentPartNum>
<ParentRevisionNum></ParentRevisionNum>
<ProdCode></ProdCode>
<RevStatusAsOfDate>0</RevStatusAsOfDate>
<SpecHedDescription></SpecHedDescription>
<vQty>0.00000000</vQty>
<Class></Class>
<IsRootNode>false</IsRootNode>
<EngineeringApproved>false</EngineeringApproved>
<InspPlanDescription></InspPlanDescription>
<PartDescriptionTrackDimension>false</PartDescriptionTrackDimension>
<PartDescriptionSellingFactor>1.00000000</PartDescriptionSellingFactor>
<PartDescriptionPartDescription>1/0 AWG WELDING CABLE ANIXTER 5J-1011</PartDescriptionPartDescription>
<PartDescriptionIUM>FT</PartDescriptionIUM>
<PartDescriptionTrackLots>false</PartDescriptionTrackLots>
<PartDescriptionPricePerCode>E</PartDescriptionPricePerCode>
<PartDescriptionSalesUM>FT</PartDescriptionSalesUM>
<PartDescriptionTrackSerialNum>false</PartDescriptionTrackSerialNum>
<PartDescriptionTypeCode>P</PartDescriptionTypeCode>
<PcStatusConfigType></PcStatusConfigType>
<PlantName>ELECTRI-CORD MFG - MN PLANT</PlantName>
<RoughCutParamDescription></RoughCutParamDescription>
<RowMod>U</RowMod>
<PPAP_c>false</PPAP_c>
<GoldenSample_c>false</GoldenSample_c>
<JobPrefix_c>FRP</JobPrefix_c>
<UD_SysRevID>AAAAAM0b4Xs=</UD_SysRevID>
</PartRev>
<PartCOPart>
<CoPartNum>10.1761</CoPartNum>
<CoRevisionNum>-</CoRevisionNum>
<PartsPerOp>1</PartsPerOp>
<LbrCostBase>1</LbrCostBase>
<MtlCostBase>1</MtlCostBase>
<IUM>FT</IUM>
<PreventSugg>false</PreventSugg>
<SysRevID>3441156477</SysRevID>
<SysRowID>13687c28-5ea7-4252-9a53-97ece7b675b2</SysRowID>
<PrimaryCost>false</PrimaryCost>
<EnablePreventSugg>false</EnablePreventSugg>
<PartMasterPart>false</PartMasterPart>
<ProcessMode></ProcessMode>
<RowMod></RowMod>
</PartCOPart>
<PartWhse>
<WarehouseCode>RAW</WarehouseCode>
<PickingQty>0.00000000</PickingQty>
<PickedQty>0.00000000</PickedQty>
<OnHandQty>0.00000000</OnHandQty>
<NonNettableQty>0.00000000</NonNettableQty>
<BuyToOrderQty>0.00000000</BuyToOrderQty>
<SalesDemandQty>0.00000000</SalesDemandQty>
<SalesReservedQty>0.00000000</SalesReservedQty>
<SalesAllocatedQty>0.00000000</SalesAllocatedQty>
<SalesPickingQty>0.00000000</SalesPickingQty>
<SalesPickedQty>0.00000000</SalesPickedQty>
<JobDemandQty>0.00000000</JobDemandQty>
<JobReservedQty>0.00000000</JobReservedQty>
<JobAllocatedQty>0.00000000</JobAllocatedQty>
<JobPickingQty>0.00000000</JobPickingQty>
<JobPickedQty>0.00000000</JobPickedQty>
<UnfirmJobDemandQty>0.00000000</UnfirmJobDemandQty>
<TFOrdDemandQty>0.00000000</TFOrdDemandQty>
<TFOrdReservedQty>0.00000000</TFOrdReservedQty>
<TFOrdAllocatedQty>0.00000000</TFOrdAllocatedQty>
<TFOrdPickingQty>0.00000000</TFOrdPickingQty>
<TFOrdPickedQty>0.00000000</TFOrdPickedQty>
<KBCode></KBCode>
<KBPONUM>0</KBPONUM>
<KBPOLine>0</KBPOLine>
<KBWarehouseCode></KBWarehouseCode>
<KBBinNum></KBBinNum>
<KBPlant></KBPlant>
<KBQty>0.00000000</KBQty>
<CalcQtyAdj>false</CalcQtyAdj>
<MinAbc></MinAbc>
<SystemAbc>C</SystemAbc>
<ManualABC>false</ManualABC>
<LastCCDate>2021-05-22T00:00:00-04:00</LastCCDate>
<OvrrideCountFreq>false</OvrrideCountFreq>
<CountFreq>0</CountFreq>
<SysRevID>2173027525</SysRevID>
<SysRowID>f300f95b-4bca-1d81-e211-07ef0cc42998</SysRowID>
<DefaultWhse>true</DefaultWhse>
<PrimBinNum></PrimBinNum>
<TotalDemand>0.00000000</TotalDemand>
<PrimBinNumDescription></PrimBinNumDescription>
<KBActionCode></KBActionCode>
<KBActionDesc></KBActionDesc>
<PlantOwner>MfgSys</PlantOwner>
<MaxQtyUOM>FT</MaxQtyUOM>
<MinQtyUOM>FT</MinQtyUOM>
<SafetyQtyUOM>FT</SafetyQtyUOM>
<IUM></IUM>
<KBBinNumDescription></KBBinNumDescription>
<KBCodeKBActionCode></KBCodeKBActionCode>
<KBCodeKBDescription></KBCodeKBDescription>
<KBPlantName></KBPlantName>
<KBWarehouseCodeDescription></KBWarehouseCodeDescription>
<PartNumIUM>FT</PartNumIUM>
<PartNumPricePerCode>E</PartNumPricePerCode>
<PartNumTrackSerialNum>false</PartNumTrackSerialNum>
<PartNumSalesUM>FT</PartNumSalesUM>
<PartNumSellingFactor>1.00000000</PartNumSellingFactor>
<PartNumTrackLots>false</PartNumTrackLots>
<PartNumPartDescription>1/0 AWG WELDING CABLE ANIXTER 5J-1011</PartNumPartDescription>
<PartNumTrackDimension>false</PartNumTrackDimension>
<WarehouseDescription>RAW MATERIAL</WarehouseDescription>
<RowMod></RowMod>
</PartWhse>
<PartUOM>
<UOMCode>FT</UOMCode>
<ConvFactor>12.0000000</ConvFactor>
<Active>true</Active>
<TrackOnHand>true</TrackOnHand>
<HasBeenUsed>false</HasBeenUsed>
<ConvOperator>*</ConvOperator>
<WebUOM>false</WebUOM>
<SysRevID>16262168</SysRevID>
<SysRowID>f300f95b-4bca-1d81-e211-07efb64a2b98</SysRowID>
<ConvFromUOM>1 FT</ConvFromUOM>
<ConvOverrride>false</ConvOverrride>
<ConvToUOM>= 12.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<EnableConvFactor>false</EnableConvFactor>
<EnableTrackOnHand>false</EnableTrackOnHand>
<GTIN14></GTIN14>
<HIBC></HIBC>
<PartSpecific>false</PartSpecific>
<UOMDesc>FOOT</UOMDesc>
<UPC12></UPC12>
<BaseUOMCode>IN</BaseUOMCode>
<DispPkgCode></DispPkgCode>
<DispPkgCodeDesc></DispPkgCodeDesc>
<DispPkgDisplaySeq>0</DispPkgDisplaySeq>
<DispPkgIsDefault>false</DispPkgIsDefault>
<PartSpecificPkgCode>false</PartSpecificPkgCode>
<DispPkgDisplayHidden>false</DispPkgDisplayHidden>
<StandardUpdate>false</StandardUpdate>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>25PER</UOMCode>
<ConvFactor>300.0000000</ConvFactor>
<TrackOnHand>false</TrackOnHand>
<NetVolume>0</NetVolume>
<NetVolumeUOM></NetVolumeUOM>
<SysRevID>0</SysRevID>
<SysRowID>9f879584-70ec-424d-9a95-00b7a0a4074f</SysRowID>
<ConvFromUOM>1 25PER</ConvFromUOM>
<ConvToUOM>= 300.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>25 FEET PER BOX</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>IN</UOMCode>
<ConvFactor>1.0000000</ConvFactor>
<SysRowID>bbe1a5fc-a3a6-dc9a-df11-0310bbf4188c</SysRowID>
<ConvFromUOM>1 IN</ConvFromUOM>
<ConvToUOM>= 1.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>INCHES</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>M</UOMCode>
<ConvFactor>39.3701000</ConvFactor>
<SysRowID>803c49c6-b6c7-6aa1-e211-e200e66d498c</SysRowID>
<ConvFromUOM>1 M</ConvFromUOM>
<ConvToUOM>= 39.3701000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>METER</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>R100FT</UOMCode>
<ConvFactor>1200.0000000</ConvFactor>
<SysRowID>f56de3bb-7bb7-829e-e211-cc01774f108a</SysRowID>
<ConvFromUOM>1 R100FT</ConvFromUOM>
<ConvToUOM>= 1200.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>100 FOOT ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>RL18YD</UOMCode>
<ConvFactor>648.0000000</ConvFactor>
<SysRowID>ee996ea1-27a7-b796-e111-9ffe8360e5fa</SysRowID>
<ConvFromUOM>1 RL18YD</ConvFromUOM>
<ConvToUOM>= 648.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>18 YARD ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>RL33FT</UOMCode>
<ConvFactor>396.0000000</ConvFactor>
<SysRowID>832b8a79-bdbd-ecac-e211-cc011891cfb3</SysRowID>
<ConvFromUOM>1 RL33FT</ConvFromUOM>
<ConvToUOM>= 396.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>33 FOOT ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>RL36YD</UOMCode>
<ConvFactor>1296.0000000</ConvFactor>
<SysRowID>8de39d3f-c864-0f83-e211-840d5cedaf9c</SysRowID>
<ConvFromUOM>1 RL36YD</ConvFromUOM>
<ConvToUOM>= 1296.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>36 YARD ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>RL50FT</UOMCode>
<ConvFactor>600.0000000</ConvFactor>
<SysRowID>7d591cde-c592-429b-8402-4f9057a3a443</SysRowID>
<ConvFromUOM>1 RL50FT</ConvFromUOM>
<ConvToUOM>= 600.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>50 FOOT ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>RL60FT</UOMCode>
<ConvFactor>720.0000000</ConvFactor>
<SysRowID>e462213a-5203-49fa-8094-0a7c50bd6cb9</SysRowID>
<ConvFromUOM>1 RL60FT</ConvFromUOM>
<ConvToUOM>= 720.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>60 FOOT ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>RL60YD</UOMCode>
<ConvFactor>2160.0000000</ConvFactor>
<SysRowID>e70b631d-1631-4c8a-e011-cfc19b79c1ea</SysRowID>
<ConvFromUOM>1 RL60YD</ConvFromUOM>
<ConvToUOM>= 2160.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>60 YARD ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>RL66FT</UOMCode>
<ConvFactor>792.0000000</ConvFactor>
<SysRowID>82a8546c-7912-fc88-e311-d58210f0d02d</SysRowID>
<ConvFromUOM>1 RL66FT</ConvFromUOM>
<ConvToUOM>= 792.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>66 FOOT ROLL</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>ST48IN</UOMCode>
<ConvFactor>48.0000000</ConvFactor>
<SysRowID>c137853b-77ea-f781-e111-7301695d5180</SysRowID>
<ConvFromUOM>1 ST48IN</ConvFromUOM>
<ConvToUOM>= 48.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>48 INCH STICK</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>TQ</UOMCode>
<ConvFactor>12000.0000000</ConvFactor>
<SysRowID>bbe1a5fc-a3a6-dc9a-df11-0310a252b6cf</SysRowID>
<ConvFromUOM>1 TQ</ConvFromUOM>
<ConvToUOM>= 12000.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>THOUSAND FEET</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<UOMCode>YD</UOMCode>
<ConvFactor>36.0000000</ConvFactor>
<SysRowID>bbe1a5fc-a3a6-dc9a-df11-03102b34dbb0</SysRowID>
<ConvFromUOM>1 YD</ConvFromUOM>
<ConvToUOM>= 36.0000000 IN</ConvToUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UOMDesc>YARD</UOMDesc>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
</PartDataSet>
</parameter>
<BpmData>
</BpmData>
</ContextDataSet>
</parameter>
</parameters>
<paramDataSetChanges>
<paramDataSet name="ds" useDataSetNbr="0">
<changedValue tableName="PartRev" rowState="Modified" rowNum="0" colName="Approved"><![CDATA[True]]></changedValue>
<changedValue tableName="PartRev" rowState="Modified" rowNum="0" colName="RowMod"><![CDATA[U]]></changedValue>
<changedValue tableName="PartRev" rowState="Modified" rowNum="0" colName="UD_SysRevID"><![CDATA[System.Byte[]]]></changedValue>
</paramDataSet>
</paramDataSetChanges>
</tracePacket>
<tracePacket>
<methodName>GetNewPartAudit</methodName>
<localTime>4/17/2024 13:04:07:1060538 PM</localTime>
<correlationId>086530a7-8647-40f2-8569-034b4c104ebb</correlationId>
<executionTime total="25" roundTrip="19" channel="0" bpm="0" bpmDataForm="0" other="6" />
<parameters>
<Part>
<IUM>FT</IUM>
<PUM>FT</PUM>
<SubPart></SubPart>
<EDICode></EDICode>
<MDPV>0</MDPV>
<AESExp></AESExp>
<HTS></HTS>
<HazSub></HazSub>
<SNMask></SNMask>
<ImageID></ImageID>
<GlbLink></GlbLink>
<PLM>false</PLM>
<RowMod></RowMod>
<CCN_c></CCN_c>
<CSRMX_c></CSRMX_c>
<CSRUS_c></CSRUS_c>
</Part>
<PartPlant>
<BuyerID></BuyerID>
<SNMask></SNMask>
<RowMod></RowMod>
</PartPlant>
<PartRev>
<DrawNum></DrawNum>
<ECO></ECO>
<Plant>MN</Plant>
<Class></Class>
<RowMod>U</RowMod>
</PartRev>
<PartAudit>
<ChangeDate>2024-04-17T00:00:00-04:00</ChangeDate>
<ChangeTime>0</ChangeTime>
<ChangedBy></ChangedBy>
<ChangeDescription></ChangeDescription>
<DspChangeTime></DspChangeTime>
<PartNumPartDescription></PartNumPartDescription>
<PartNumIUM></PartNumIUM>
<PartNumSalesUM></PartNumSalesUM>
<PartNumSellingFactor>1</PartNumSellingFactor>
<RevisionNumRevShortDesc></RevisionNumRevShortDesc>
<RevisionNumRevDescription></RevisionNumRevDescription>
<RowMod>A</RowMod>
</PartAudit>
<PartCOPart>
<IUM>FT</IUM>
<RowMod></RowMod>
</PartCOPart>
<PartWhse>
<KBCode></KBCode>
<KBPlant></KBPlant>
<MinAbc></MinAbc>
<IUM></IUM>
<RowMod></RowMod>
</PartWhse>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
</PartDataSet>
</parameter>
<parameter name="partNum" type="System.String"><![CDATA[10.1761]]></parameter>
<parameter name="revisionNum" type="System.String"><![CDATA[-]]></parameter>
<parameter name="altMethod" type="System.String"><![CDATA[]]></parameter>
<parameter name="processMfgID" type="System.String"><![CDATA[]]></parameter>
<parameter name="changeDate" type="System.DateTime"><![CDATA[4/17/2024 12:00:00 AM]]></parameter>
<BpmData>
</BpmData>
</ContextDataSet>
</parameter>
</parameters>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="Company"><![CDATA[ECM]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNum"><![CDATA[10.1761]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="RevisionNum"><![CDATA[-]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="ChangeDate"><![CDATA[4/17/2024 12:00:00 AM]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="ChangeTime"><![CDATA[0]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="ChangedBy"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="ChangeDescription"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="AltMethod"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="SysRevID"><![CDATA[0]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="SysRowID"><![CDATA[00000000-0000-0000-0000-000000000000]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="ProcessMfgID"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="DspChangeTime"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="BitFlag"><![CDATA[0]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumTrackDimension"><![CDATA[False]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumTrackLots"><![CDATA[False]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumPartDescription"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumPricePerCode"><![CDATA[E]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumTrackSerialNum"><![CDATA[False]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumIUM"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumSalesUM"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="PartNumSellingFactor"><![CDATA[1]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="RevisionNumRevShortDesc"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="RevisionNumRevDescription"><![CDATA[]]></changedValue>
<changedValue tableName="PartAudit" rowState="Added" rowNum="0" colName="RowMod"><![CDATA[A]]></changedValue>
</paramDataSet>
</tracePacket>
<tracePacket>
<localTime>4/17/2024 13:04:07:1379133 PM</localTime>
<correlationId>6467b043-96f8-4f49-b618-44a210e39b2a</correlationId>
<executionTime total="402" roundTrip="395" channel="0" bpm="0" bpmDataForm="0" other="7" />
<parameters>
<Part>
<IUM>FT</IUM>
<PUM>FT</PUM>
<PurchasingFactor>1</PurchasingFactor>
<UnitPrice>0</UnitPrice>
<InternalUnitPrice>0</InternalUnitPrice>
<UserDecimal1>0</UserDecimal1>
<UserDecimal2>0</UserDecimal2>
<UserDecimal3>0</UserDecimal3>
<UserDecimal4>0</UserDecimal4>
<SellingFactor>1</SellingFactor>
<MtlBurRate>0</MtlBurRate>
<NetWeight>0</NetWeight>
<PartLength>0</PartLength>
<PartWidth>0</PartWidth>
<PartHeight>0</PartHeight>
<SubPart></SubPart>
<Diameter>0</Diameter>
<Gravity>0</Gravity>
<ISSuppUnitsFactor>1</ISSuppUnitsFactor>
<EDICode></EDICode>
<MDPV>0</MDPV>
<AESExp></AESExp>
<HTS></HTS>
<HazSub></HazSub>
<RCUnderThreshold>0</RCUnderThreshold>
<RCOverThreshold>0</RCOverThreshold>
<SNMask></SNMask>
<GrossWeight>0</GrossWeight>
<FSSalesUnitPrice>0</FSSalesUnitPrice>
<PricingFactor>0</PricingFactor>
<DiameterInside>0</DiameterInside>
<DiameterOutside>0</DiameterOutside>
<Thickness>0</Thickness>
<ThicknessMax>0</ThicknessMax>
<ImageID></ImageID>
<FairMarketValue>0</FairMarketValue>
<LCNRVEstimatedUnitPrice>0</LCNRVEstimatedUnitPrice>
<CNWeight>0</CNWeight>
<FSAInstallationCost>0</FSAInstallationCost>
<GlbLink></GlbLink>
<PLM>false</PLM>
<Revision>true</Revision>
<RowMod></RowMod>
<Number01>0</Number01>
<Number05>0</Number05>
<Number06>0</Number06>
<CCN_c></CCN_c>
<Commission1_c>0.00</Commission1_c>
<Commission2_c>0.00</Commission2_c>
<DiscountPct_c>0.00</DiscountPct_c>
<CSRMX_c></CSRMX_c>
<CSRUS_c></CSRUS_c>
<CopperWeight_c>0.00</CopperWeight_c>
</Part>
<PartPlant>
<BuyerID></BuyerID>
<SNMask></SNMask>
<RowMod></RowMod>
</PartPlant>
<PartRev>
<ApprovedDate>2024-04-17T00:00:00-04:00</ApprovedDate>
<ApprovedBy>ComTec</ApprovedBy>
<TLRLaborCost>0</TLRLaborCost>
<TLRBurdenCost>0</TLRBurdenCost>
<TLRMaterialCost>0</TLRMaterialCost>
<TLRSubcontractCost>0</TLRSubcontractCost>
<TLRMtlBurCost>0</TLRMtlBurCost>
<TLRSetupLaborCost>0</TLRSetupLaborCost>
<TLRSetupBurdenCost>0</TLRSetupBurdenCost>
<LLRLaborCost>0</LLRLaborCost>
<LLRBurdenCost>0</LLRBurdenCost>
<LLRMaterialCost>0</LLRMaterialCost>
<LLRSubcontractCost>0</LLRSubcontractCost>
<LLRMtlBurCost>0</LLRMtlBurCost>
<LLRSetupLaborCost>0</LLRSetupLaborCost>
<LLRSetupBurdenCost>0</LLRSetupBurdenCost>
<DrawNum></DrawNum>
<ECO></ECO>
<Plant>MN</Plant>
<RMASampleSize>0</RMASampleSize>
<RMASampleSizePct>0</RMASampleSizePct>
<SysRevID>3441156499</SysRevID>
<CoPartsReqQty>0</CoPartsReqQty>
<MtlCostPct>0</MtlCostPct>
<LaborCostPct>0</LaborCostPct>
<ChangedOn>2024-04-17T17:04:07.2197473-04:00</ChangedOn>
<Class></Class>
<RowMod></RowMod>
</PartRev>
<PartAudit>
<ChangeTime>47047</ChangeTime>
<ChangeDescription>test</ChangeDescription>
<SysRevID>3441156500</SysRevID>
<SysRowID>ed1d8ae0-8ae9-441e-95bc-5dc567892ed1</SysRowID>
<DspChangeTime> 1:04 PM</DspChangeTime>
<RowMod></RowMod>
</PartAudit>
<PartCOPart>
<IUM>FT</IUM>
<RowMod></RowMod>
</PartCOPart>
<PartWhse>
<KBCode></KBCode>
<KBPlant></KBPlant>
<MinAbc></MinAbc>
<IUM></IUM>
<RowMod></RowMod>
</PartWhse>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
<PartUOM>
<EAN13></EAN13>
<EAN14></EAN14>
<EAN8></EAN8>
<GTIN14></GTIN14>
<HIBC></HIBC>
<UPC12></UPC12>
<RowMod></RowMod>
</PartUOM>
</PartDataSet>
</parameter>
<BpmData>
</BpmData>
</ContextDataSet>
</parameter>
</parameters>
</tracePacket>
For some reason, I do not think this is displaying correctly on here…
When a Revision is approved, a PartAudit record is created and it needs to be filled out, including the change made. If you look at the trace of the approval when running manually, you will see this record populated.
