BAQ help for Top Ten Customers / Vendors
I would like to take a look at that Top customer dashboard. Would love to see how you did that.
--- In vantage@yahoogroups.com, effgroups@... wrote:
> Why not post it to the group files.
> Lot of us could make good use of your expertise.
> Thanks
> Ephraim Feldman
> -----Original Message-----
> From: Mark Wagner <mjfw2003@...>
> Date: Mon, 26 Apr 2010 15:47:50
> To: <vantage@yahoogroups.com>
> Subject: Re: [Vantage] BAQ help for Top Ten Customers / Vendors
> With bookings I guess you want sales order dollars instead of invoice dollars? With the date range, you can just put that on the dashboard to pull in sales order dollars by date range. Do you want only line charges without taxes and/or misc charges?
> ÂÂ
> Same thing for open PO dollars
> ÂÂ
> I have both BAQs so if you send me an email address I can attach the BAQ for each and you can adapt as needed to your requirements
> --- On Mon, 4/26/10, Leslie Martin <lmartin.allwire@...> wrote:
> From: Leslie Martin <lmartin.allwire@...>
> Subject: [Vantage] BAQ help for Top Ten Customers / Vendors
> To: "Vantage Usergroup" <vantage@yahoogroups.com>
> Date: Monday, April 26, 2010, 6:11 PM
> ÂÂ
> Hello,
> I've been asked to make a report or BAQ showing our top ten customers or vendors with a date range. I'm not sure what tables to pull from to get the data.
> I need to show booked order dollars by Month.
> With the vendors, I need to show our open PO dollars by month.
> I'm sure if I can get one to work, the other will be easy.
> Thanks!
> Leslie Martin
> Allwire Inc.
Hello,
Thanks!
Leslie Martin
Allwire Inc.
Â
Â
Â
Hello,
Thanks!
Leslie Martin
Allwire Inc.
Hi Leslie,
Also, see the discussion from 3-18-2010 "Vantage - Top Customer Report" submitted by Chris T. To sort for Top Ten, Steven G. has a solution with custom fields, and I have a solution using Crystal Reports functionality.
Laraine
> ÂÂ
> ÂÂ
> ÂÂ
> Hello,
> Thanks!
> Leslie Martin
> Allwire Inc.
Mark, I am also trying to get the top suppliers for last 3-months of
receipts. I think that your BAQ will be of great help to get me started.
If you be so kind could you send it to me also.
Oscar Hernandez
ohernandez@...
Vantage 8.03.408B on SQL.
Implemented on Oct 1/09
_____
Mark Wagner
Sent: Monday, April 26, 2010 3:48 PM
<mailto:lmartin.allwire%40yahoo.com> yahoo.com> wrote:
From: Leslie Martin <lmartin.allwire@ <mailto:lmartin.allwire%40yahoo.com>
yahoo.com>
<mailto:vantage%40yahoogroups.com> .com>
Hello,
data.
Thanks!
Leslie Martin
Allwire Inc.
Ephraim Feldman
Â
Â
Â
Hello,
Thanks!
Leslie Martin
Allwire Inc.
