Whoo hoo….anytime! Manasa
Sent: Thursday, April 09, 2015 4:27 PM
Subject: RE: [Vantage] RE: BAQ Help - E904.507A
Manasa,
I did get the one-off fix, (2 DLL Files for the client), replaced those and now I can join tables to my heart’s content!
I wish I had followed thru on this YEARS ago.
So for reference, if anyone is left on 9.04.507A and has problems getting BAQ joins to work, get SCR 78693 from support.
Thanks for the push to do it.
Jim
Sent: Wednesday, April 01, 2015 6:25 AM
Yep that would do it….and they probably fixed it 9.05! You should see if they can send a one off if possible to fix it…..
Manasa
Sent: Tuesday, March 31, 2015 5:06 PM
Thanks for the replies.
That is the way I originally tried to do it, the way Manasa mentioned.
I went ahead and tried it again with a fresh BAQ and it still says there is more than one root table.
I did some looking way back in messages and there was a message saying something about a bug in 9.04.507a called out in SCR 78693.
I wonder if that’s the issue.
Jim
Sent: Tuesday, March 31, 2015 1:37 PM
To: Vantage
Subject: Re: [Vantage] RE: BAQ Help - E904.507A
Sometimes when you addd a table and remove it , then add it etc.. BAQ Designer gets all sticky , just close re-launch and then do the joins like Manasa suggested
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez>
[Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by
sender.] <http://www.josecgomez.com/feed/>
On Tue, Mar 31, 2015 at 2:21 PM, Manasa Reddy
manasa.reddy@...<mailto:manasa.reddy@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
If you are not doing it this way it should be POHead to PODetail then PODetail to PORel….I’d clear the links and start again make sure only the three tables are there then link them.
Manasa
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
Sent: Tuesday, March 31, 2015 1:34 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Subject: [Vantage] BAQ Help - E904.507A
I am trying to join POHeader, PORel and PODetail, I keep getting the error that More than one root table is detected.
Can anyone tell me a way to join these tables in BAQ Designer.
I suspect there is another table that I need to use to accomplish this but I have not been able to figure it out.
Any help is appreciated.
Jim Moore
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please
contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
