Looking to write a BAQ to extract who has access to what Menu Security Codes. When I look in the Menu Security module, the tables listed on some of the fields is not listed in the BAQ options.
Has anyone written something like this?
Dyan
Pretty sure there are others here on posts as well
I can’t open your BAQ, Can you please post what tables with reference tables and columns displaying on report.
Kumar
* Disclaimer!!!
* This is not a real query being executed, but a simplified version for general vision.
* Executing it with any other tool may produce a different result.
with [CTE] as
(select
[CTEMenu].[Company] as [CTEMenu_Company],
[CTEMenu].[ParentMenuID] as [CTEMenu_ParentMenuID],
[CTEMenu].[MenuID] as [CTEMenu_MenuID],
[CTEMenu].[SecCode] as [CTEMenu_SecCode],
[CTEMenu].[Sequence] as [CTEMenu_Sequence],
[CTEMenu].[MenuDesc] as [CTEMenu_MenuDesc],
(1) as [Calculated_Level],
(CAST(CTEMenu.MenuDesc as varchar(2000))) as [Calculated_MenuPath]
from Ice.Menu as CTEMenu
where (CTEMenu.ParentMenuID = '')
union all
select
[CTE2Menu].[Company] as [CTE2Menu_Company],
[CTE2Menu].[ParentMenuID] as [CTE2Menu_ParentMenuID],
[CTE2Menu].[MenuID] as [CTE2Menu_MenuID],
[CTE2Menu].[SecCode] as [CTE2Menu_SecCode],
[CTE2Menu].[Sequence] as [CTE2Menu_Sequence],
[CTE2Menu].[MenuDesc] as [CTE2Menu_MenuDesc],
(CTE.Calculated_Level + 1) as [Calculated_Level],
(CAST(CAST(CTE.Calculated_MenuPath as varchar(2000)) + CAST(' -> ' as varchar(2000)) + CAST(CTE2Menu.MenuDesc as varchar(2000)) AS varchar(2000))) as [Calculated_MenuPath]
from Ice.Menu as CTE2Menu
inner join CTE as CTE on
CTE2Menu.ParentMenuID = CTE.CTEMenu_MenuID)
select
[CTE1].[CTEMenu_Company] as [CTEMenu_Company],
[CTE1].[CTEMenu_ParentMenuID] as [CTEMenu_ParentMenuID],
[CTE1].[CTEMenu_MenuID] as [CTEMenu_MenuID],
[CTE1].[CTEMenu_SecCode] as [CTEMenu_SecCode],
[CTE1].[CTEMenu_Sequence] as [CTEMenu_Sequence],
[CTE1].[CTEMenu_MenuDesc] as [CTEMenu_MenuDesc],
[CTE1].[Calculated_Level] as [Calculated_Level],
[CTE1].[Calculated_MenuPath] as [Calculated_MenuPath],
[MenuSecurity].[Security_EntryList] as [Security_EntryList],
[MenuSecurity].[Security_NoEntryList] as [Security_NoEntryList],
[MenuSecurity].[Security_SecurityMgr] as [Security_SecurityMgr]
from CTE as CTE1
inner join (select
[Security].[Company] as [Security_Company],
[Security].[SecCode] as [Security_SecCode],
[Security].[EntryList] as [Security_EntryList],
[Security].[NoEntryList] as [Security_NoEntryList],
[Security].[SecurityMgr] as [Security_SecurityMgr]
from Ice.Security as Security
where (Security.ParentSecCode = 'MENU')) as MenuSecurity on
CTE1.CTEMenu_SecCode = MenuSecurity.Security_SecCode
Thanks you Michael, I tried to reproduce BAQ with your query but I couldn’t succeeded. Can you please provide info subquery list with diagrams.
Kumar
Here I enclosed my query
Query
with [CTE] as
(select
(CAST(CTEMenu.MenuDesc as varchar(2000))) as [Calculated_MenuPath],
from Ice.Menu as [CTEMenu]
where (CTEMenu.ParentMenuID = ‘’)
union all
select
from Ice.Menu as [CTE2Menu]
full outer join as [CTE] on
CTE2Menu.ParentMenuID = CTE.Menu_MenuID)
select *
from CTE as [CTE1]
inner join Ice.Security as [Security]
But I need to finish query diagrams. Just I want to check with you sequence of sub queries correct or not. Please help me,
I figured it out and fixed the query. Now it is working and thanks for your script.
