It is listed in the supplied help files that you can access from anywhere within the vantage application. No manual, but it is buried in the help file.
To: vantage@yahoogroups.comFrom: sanfranc415@...: Wed, 30 May 2007 22:24:19 +0000Subject: [Vantage] Re:BAQ for Employee Hire Dates
Where is this documentation that you're referrering to?--- In vantage@yahoogroups.com, Carey S <rotary1@...> wrote:>> This is actually documented in the Vantage 8.00.810 help files for PR and specifically mention that adjustments to class data will not show up until "program restart" which ultimately refers to Vantage client app vs PR program. So, this is standard par here.> > Carey> > > To: vantage@...: sue.jones@...: Mon, 21 May 2007 06:09:30 -0400Subject: [Vantage] Re:BAQ for Employee Hire Dates> > > > > Good Morning,The same thing happened to me. We have 4 companies and in switching todo payroll, 2 of my classes refused to show up in the payroll group.Not knowing what else to do, since I'm set up as payroll manager withaccess all classes, I logged in again. Surprise! It worked - all of myclasses showed up in my payroll group. So each time I switch companies,I have to log in again or my access to all classes is altered. Soundslike a patch is needed here. Give this a try and see if it works.Sue JonesOffice Manager/Human Resources PH: 616-785-5748FAX: 616-785-2955[Non-text portions of this message have been removed] > > > __________________________________________________________> Create the ultimate e-mail address book. Import your contacts to Windows Live Hotmail.> www.windowslive-hotmail.com/learnmore/managemail2.html?locale=en-us&ocid=TXT_TAGLM_HMWL_reten_impcont_0507> > [Non-text portions of this message have been removed]>
_________________________________________________________________
