BAQ Error
I am trying to do a simple BAQ and just have crazy issues. I am sure I am missing something simple.
I have PartBin and WhseBin (only non-netteable)
I am trying to sum the Parts on hand. They are in multiple bin locations and i get the following error. i am using TOTAL to calculate total On hand Qty.
PartBin Company must be a quoted constant or an unabbreviated, unambiguous buffer/field reference for buffers known to query . (7328)
Is this total on hand per part per warehouse?
Or total pieces on hand per bin?
Or total pieces on hand per part per bin?
Try first making the BAQ without summing up the QOH by Partnum.
The Query Phrase in E10 is
select
	[PartBin].[PartNum] as [PartBin_PartNum],
	[PartBin].[BinNum] as [PartBin_BinNum],
	[PartBin].[OnhandQty] as [PartBin_OnhandQty],
	[WhseBin].[NonNettable] as [WhseBin_NonNettable]
from Erp.PartBin as PartBin
inner join Erp.WhseBin as WhseBin on
	PartBin.Company = WhseBin.Company
And
	PartBin.WarehouseCode = WhseBin.WarehouseCode
And
	PartBin.BinNum = WhseBin.BinNum
 and ( WhseBin.NonNettable = FALSE  )
If you can’t get that to work, try it without having the table criteria that filters on non-netable
If the query works, go back and remove the PartBin and Non-Nettable from the displayed fields. Then apply grouping by partnumber and add the calculated field for TOTAL(OnHandQty).
I know E10 is different, but your query phrase should look something like:
select
	(SUM(PartBin.OnhandQty)) as [Calculated_QOHinNonNetable]
And
And
 and ( WhseBin.NonNettable = TRUE)
group by [PartBin].[PartNum]
I ended doing a View in SQl and creating an External BAQ.
