I am not very familiar with BAQ DataViews, but I did do some digging and it looks like it’s relatively painless to set up the dataview and bind it to the transaction object within a form. It looks like then, you subscribe the data in the BAQ dataview to a column(s) in another view to relate the data.
I have a dashboard assembly that already uses some pub/sub dashboard features in order to drive the data in the different panels.
The end goal is to bring in a new column into one of the queries/panels with the results from a separate BAQ. These are currently (and will likely remain) 2 distinct BAQs.
The first BAQ returns data with the QuoteDtl_QuoteNum field as key. I want to relate the second BAQ (the BAQDataView data) on QuoteNum as well, and then return a column from its data and meld them together in the grid.
I am having trouble getting the thing to work however.
Here is my dataview code:
private void CreateOrderBucketsView()
//Connects the BAQView to the EDV on Quote Num
baqViewOrderBuckets = new BAQDataView("OPS_OrderBuckets");
oTrans.Add("OrderBucketsBAQView", baqViewOrderBuckets);
EpiDataView edvQ = (EpiDataView)oTrans.EpiDataViews["V_JRF_Quotes_1View"];
string pub1Binding = edvQ.dataView[edvQ.Row]["QuoteDtl_QuoteNum"].ToString();
IPublisher pub1 = oTrans.GetPublisher(pub1Binding);
if(pub1==null)
string pubName = Guid.NewGuid().ToString();
oTrans.PublishColumnChange(pub1Binding, pubName);
if(pub1!=null)
baqViewOrderBuckets.SubscribeToPublisher(pub1.PublishName, "QuoteHed_QuoteNum");
From my understanding, the pub1Binding
variable stores the name of the column in another dataview that I will be relating the data from the BAQ on.
I tired calling this during the InitalizeCode()
, but it fails to work, probably because there is no native dataview value to bind to.
Application Error
Exception caught in: mscorlib
Error Detail
Message: Exception has been thrown by the target of an invocation.
Inner Exception Message: Index -1 is either negative or above rows count.
Program: CommonLanguageRuntimeLibrary
Method: InvokeMethod
Client Stack Trace
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Ice.Lib.Customization.CustomScriptMethodInvoker.InvokeScriptMethod(MethodInfo scriptMethod, Object[] parameters)
at Ice.Lib.Customization.CustomScriptMethodInvoker.InvokeInitializeCustomCodeIfExists()
at Ice.Lib.Customization.CustomScriptManager.TryActionShowExceptionBoxOrLogVerificationErrorIfException(Action action, String exceptionBoxTitle)
Inner Exception
at System.Data.DataView.GetRow(Int32 index)
at Script.CreateOrderBucketsView()
at Script.InitializeCustomCode()
I’m sure I’m doing something wrong, but any guidance would be very much appreciated!
@Carson I used your code and watched your video, much appreciated by the way
