I’ve been going through all the posts related to BAQ Data Views to try and set up my own. I’ve gotten as far as creating the View itself from my BAQ but the only fields that display are those associated with the standard POTracker Dataset (PONum, Line, Release, Job, Asm, Seq); the rest of the fields in the view do not display data. The BAQ itself displays everything fine.
This is a customization of PO Tracker to add some part attribute fields from a related QuoteMtl_UD table.
Any thoughts?
Here’s the code:
extern alias Erp_Contracts_BO_Vendor; extern alias Erp_Contracts_BO_Company; extern alias Erp_Contracts_BO_Part; extern alias Erp_Contracts_BO_VendorPPSearch; extern alias Erp_Contracts_BO_VendCntSearch; extern alias Erp_Contracts_BO_PO; extern alias Erp_Contracts_BO_MiscShip; extern alias Erp_Contracts_BO_Receipt; extern alias Erp_Contracts_BO_Plant; extern alias Erp_Contracts_BO_JobEntry; extern alias Erp_Contracts_BO_JobMtlSearch;using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.Lib.Broadcast;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
BAQDataView baqPartAttributes;
CreateLateBAQView();
// Begin Custom Code Disposal
// End Custom Code Disposal
public void CreateLateBAQView()
baqPartAttributes = new BAQDataView("CC_PORel_QuoteAttributes");
oTrans.Add("CC_PORel_QuoteAttributes",baqPartAttributes);
string pubBinding = "POHeader.PONum";
IPublisher pub = oTrans.GetPublisher(pubBinding);
if(pub==null)
oTrans.PublishColumnChange(pubBinding, "MyCustomPublish");
if(pub !=null)
baqPartAttributes.SubscribeToPublisher(pub.PublishName, "PORel_PONum");
pubBinding = "PODetail.POLine";
IPublisher pub2 = oTrans.GetPublisher(pubBinding);
if(pub2==null)
oTrans.PublishColumnChange(pubBinding, "MyCustomPublish2");
if(pub2 !=null)
baqPartAttributes.SubscribeToPublisher(pub2.PublishName, "PORel_POLine");
pubBinding = "PORel.PORelNum";
IPublisher pub3 = oTrans.GetPublisher(pubBinding);
if(pub3==null)
oTrans.PublishColumnChange(pubBinding, "MyCustomPublish3");
if(pub3 !=null)
baqPartAttributes.SubscribeToPublisher(pub3.PublishName, "PORel_PORelNum");
