Hi Bruce,
Can you remind me what the difference is between an inner and outer join?
Cheers.
Sent: Thursday, 18 June, 2009 17:37:29
Subject: RE: [Vantage] BAQ & Dashboard
To delete the links - select the link and go to the table relations sheet
and click on the delete icon.
In E9 to create a new link, click on the Add Connection ("Chain" icon)
Click on the first and second table that you want to link.
Note that it defaults to an inner join.
To modify the link, click on the specific link and go to the Table Relations
sheet.
Bruce
bruce@ERPgeek. com
www.ERPgeek. com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Chris Thompson
Sent: Thursday, June 18, 2009 10:04 AM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] BAQ & Dashboard
How do you remove an epicor link between table and creat your own?
In E9 I think it is more complicated?
____________ _________ _________ __
Sent: Wednesday, 17 June, 2009 17:53:40
The BAQ wizard rarely creates joins in the way you need (when the query is
even moderately complex). Get used to establishing your own joins that suit
your specific needs.
Rob Brown
Sent: Wednesday, June 17, 2009 11:51:48 AM
As soon as I add the JobHead table it increase the number of lines.
Which table relations should I be using?
It has automatically connect with JobHead as the Parent and JobOper as the
child with Company and JobNum as the relations.
Sent: Wednesday, 17 June, 2009 16:43:23
Add the jobhead table...part can come from there...if you need the
description as well, then add the part table to that!
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of Chris Thompson
Sent: Wednesday, June 17, 2009 10:38 AM
I think I have it almost.
I have linked the JobOper to LaborDtl in the opposite direction and that
is pulling through the correct Opr Descriptions.
The only thing now is to bring in the part number from somewhere. But
where? I have added it from the JobOper table and it displays a black
field so Im guessing its not that one! :-)
From: Manasa Reddy <manasa@weldcoa. com <mailto:manasa% 40weldcoa. com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Sent: Wednesday, 17 June, 2009 16:30:51
Just thinking that since you only want qty reported, correct? Then
filter for qty greater than zero....
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of Manasa Reddy
Sent: Wednesday, June 17, 2009 10:18 AM
Can you send me your links, because my report doesn't give all
operations.. ..
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@ yahoogroups .com <mailto:vantage% 40yahoogroups. com> ]
On
Behalf
Of Manasa Reddy
Sent: Wednesday, June 17, 2009 10:10 AM
It should be a straight forward join....
How are you filtering?
I'm wondering if you need to join the JobOper table to get only the
operations on the job?
I'll do this in crystal and see what happens as well...
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
<mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of Chris Thompson
Sent: Wednesday, June 17, 2009 9:57 AM
I have added the OpMaster table but that has just added hundreds or
repeat lines.
Will that be something to do with the join or table relationship or am I
on the wrong table.
Cheers,
Sent: Wednesday, 17 June, 2009 15:37:54
qty is in the labor dtl table...the qty the operator finished.
I think you can link the operation table to the labor dtl table as well
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of Chris Thompson
Sent: Wednesday, June 17, 2009 9:35 AM
No, I know how to create a BAQ, but I need to pull in the OprDescription
and the qty that the operator has worked on.
Sent: Wednesday, 17 June, 2009 15:29:27
Unless you were asking how to create a BAQ....?
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of Chris Thompson
Sent: Wednesday, June 17, 2009 9:23 AM
Subject: [Vantage] BAQ & Dashboard
Hi,
Im trying to create a simple (or so I thought) BAQ to report what job
and operation an operator has done and how long it took them, and how
many parts they worked on.
I want to know the following:
Date | Operator Name | Start Time | End Time | Job Number | Part |
Operation | Quantity | Standard Time | Type
Does any know where I should begin?
Does anyone have a BAQ like this that I may 'aquire'?
CHRIS THOMPSON
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Cheers.
sheet.
Bruce
bruce@ERPgeek. com
www.ERPgeek. com
Chris Thompson
Rob Brown
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Of Chris Thompson
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of Manasa Reddy
operations.. ..
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
On
Behalf
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of Chris Thompson
repeat lines.
on the wrong table.
Cheers,
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of Chris Thompson
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of Chris Thompson
Hi,
CHRIS THOMPSON
