I am seeing some really strange behavior in a BAQ and in a Dashboard. I am working in the BAQ because there are no customizations or code in place, just a raw BAQ.
When I run the BAQ to generate results, they display but not fully. What I mean is, when I click on one of the columns, then and only then does it show the full cell data. It’s not a field size issue, I dragged the column wider but it makes no difference.
Here is exactly what it looks like
WITHOUT any clicking
WITH clicking on the value (underlined in red is what show up when and only when I click the field)
Any ideas what is causing this or how to fix it? It seems like a bug to me. ??
That seems likely, the engineer brought in this data via DMT. Any ideas on how to “see” if there is carriage return in the column value? I’ll take a look in SSMS.
I was able to copy/paste the column value from SSMS into Notepad. Sure enough, there’s a carriage return! I didn’t realize you could use them in that way. Thanks for the tip @Mark_Wonsil!
