Does changing a BAQ used by a deployed dashboard - without re-deploying - cause the dashboard to operate differently?
For example, if a dashboard used a BAQ that had a hard coded table criteria (say Orderhed.OrdeDate >= 1/1/2017), and that dashboard was deployed.
Would changes to the BAQ ( like changing that criteria to 1/1/2016), be reflected when the deployed dashboard is run?
Or does the dashboard need to be re-deployed?
