BAQ: Case expressions may only be nested to level 10
Hi, I am trying to write a report for our GL account budgets, broken down by monthly amounts. We soft close 52 periods on a 4-4-5 schedule. So my budgets are loaded by periods, and I’m trying to calculate the month from the period. Here is the nested case expression i’m using, which should work great, but I get the error: “Case expressions may only be nested to level 10.”
Anyone have an idea of another way I could conclude the month from the period?
  case when (
    1 <= GLBudgetDtl.FiscalPeriod
    and GLBudgetDtl.FiscalPeriod <= 4
  ) then 1 else (
    case when (
      5 <= GLBudgetDtl.FiscalPeriod
      and GLBudgetDtl.FiscalPeriod <= 8
    ) then 2 else (
      case when (
        9 <= GLBudgetDtl.FiscalPeriod
        and GLBudgetDtl.FiscalPeriod <= 13
      ) then 3 else (
        case when (
          14 <= GLBudgetDtl.FiscalPeriod
          and GLBudgetDtl.FiscalPeriod <= 17
        ) then 4 else (
          case when (
            18 <= GLBudgetDtl.FiscalPeriod
            and GLBudgetDtl.FiscalPeriod <= 21
          ) then 5 else (
            case when (
              22 <= GLBudgetDtl.FiscalPeriod
              and GLBudgetDtl.FiscalPeriod <= 26
            ) then 6 else (
              case when (
                27 <= GLBudgetDtl.FiscalPeriod
                and GLBudgetDtl.FiscalPeriod <= 30
              ) then 7 else (
                case when (
                  31 <= GLBudgetDtl.FiscalPeriod
                  and GLBudgetDtl.FiscalPeriod <= 34
                ) then 8 else (
                  case when (
                    35 <= GLBudgetDtl.FiscalPeriod
                    and GLBudgetDtl.FiscalPeriod <= 39
                  ) then 9 else (
                    case when (
                      40 <= GLBudgetDtl.FiscalPeriod
                      and GLBudgetDtl.FiscalPeriod <= 43
                    ) then 10 else (
                      case when (
                        44 <= GLBudgetDtl.FiscalPeriod
                        and GLBudgetDtl.FiscalPeriod <= 47
                      ) then 11 else 12 end
                    ) end
                  ) end
                ) end
              ) end
            ) end
          ) end
        ) end
      ) end
    ) end
  ) end
Why do you need to nested statement? just use
(case
    when  (1 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 4) then 1
    when (5 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 8)  then 2
end)
etc
That is exactly what I needed to see! Did not realize I could write it like that. Thanks so much!!
case
    when (9 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 13) then 3
    when (14 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 17) then 4
    when (18 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 21) then 5
    when (22 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 26) then 6
    when (27 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 30) then 7
    when (31 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 34) then 8
    when (35 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 39) then 9
    when (40 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 43) then 10
    when (44 <= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 47) then 11
else 12
end
I think you wanted >= on the first first half of each ANDed condition…
when (1 >= GLBudgetDtl.FiscalPeriod and GLBudgetDtl.FiscalPeriod <= 4) then 1
// note the above is incorrect!  See "whoops" below
WHOOPS!!!
The <= is correct, because you have the constant on the other side.
(I always put the variable first)
But you don’t need the first half of each ANDed condition at all
is the same as
when (GLBudgetDtl.FiscalPeriod <= 4) then 1
Hi Calvin, good point on the AND. That would work on the first condition, but wouldn’t it fail if I did that on every condition in the statement? If it was period 1, I would want to return month 1, but this would not work, because both conditions are met:
when (GLBudgetDtl.FiscalPeriod <= 8) then 2
once it satisfies one, it’s done. It doesn’t keep going through the loop. So make sure you pay attention to the order when you make something like this.
Ah, got it. Thank you for the clarification!
3 posts were split to a new topic: Musings on random ways to do things
@ckrusen is that really relevant?
Calvin - I usually put the variable first too :slight_smile: I was seeing if it would accept 1 < x < 4, but it did not like that, and inserting an AND statement was the quickest edit haha
