String(JobHead.JobNum) + “ “ + String(OrderHed.OrderNum)
Just guessing here
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Sent: Monday, March 21, 2011 8:46 AM
Subject: Re: [Vantage] BAQ Calculated Fields
Great thanks.
Do you know how I might be able to get a space in between them?
From: Karen Schoenung <kschoenung@...<mailto:kschoenung%40fisher-barton.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Mon, 21 March, 2011 13:26:09
Subject: RE: [Vantage] BAQ Calculated Fields
Per Answer book # 3643ESC, concantenate looks like you need "+"
String(JobHead.JobNum) + String(OrderHed.OrderNum)
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Chris Thompson
Sent: Monday, March 21, 2011 8:02 AM
Subject: [Vantage] BAQ Calculated Fields
Hi All
I want to try and create a calculated field which will combine the data from two
cells.
if isNull(JobHead.JobNum) then OrderHed.OrderNum else < This bit works ok
String(JobHead.JobNum) & String(OrderHed.OrderNum) < This doesnt work
I want the outcome to be 01264789 998877 ...
Where 01264789 is the JobNum and 998877 is the OrderNum.
They dont even need a space inbetween, it could just be one long string.
Does anyone know how to join the two field's output together?
Thanks.
Just guessing here
Great thanks.
Chris Thompson
Hi All
cells.
Thanks.
