BAQ Calculated Field
Would you still expect this to work even if the first calculated field was based on a summarised table? Thanks.
--- In vantage@yahoogroups.com, effgroups@... wrote:
> It worked for me.
> But I discovered over time that the first calculated field must be created before the second if not it doesn't work.
> Ephraim Feldman
> -----Original Message-----
> From: "Brian Roberts" <broberts@...>
> Sender: vantage@yahoogroups.com
> Date: Thu, 19 Jul 2012 15:00:31
> To: <vantage@yahoogroups.com>
> Reply-To: vantage@yahoogroups.com
> Subject: RE: [Vantage] BAQ Calculated Field
> Worked for me in 9.05.607B for a couple simple ones, don't remember
> doing anything special.
> First calc field is: ShipDtl.OurInventoryShipQty + ShipDtl.OurJobShipQty
> Second is: OrderRel.OurReqQty - OurShipQty
> Brian.
> Of Len Hartka
> Sent: Thursday, July 19, 2012 2:48 PM
> Good Day Brian:
> What version are you on
> I have tried using a calc-field in another calc-field and it did not
> work. Have you actually done it?
> Maybe works sometimes? Depend on files, fields; calculation, etc.
> Sun is on 9.05.605 since 10/2/11 - SQL-Unidata- 64 bit
> Live on 9.05.601B since 11/29/10
> Sun was previously on M2K (Manage-2000) 7.0 SP 5 (Informix)
> len.hartka@... <mailto:len.hartka%40sunautomation.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> Of Brian Roberts
> Sent: Thursday, July 19, 2012 2:31 PM
> Not possible, the BAQ calculated field syntax is a single expression.
> However, you can define one calculated field to hold part of a complex
> expression, then use that in a second calculated field.
> Thanks,
> Brian.
> Behalf
> Of tkoch77
> Sent: Thursday, July 19, 2012 12:08 PM
> Subject: [Vantage] BAQ Calculated Field
> Is it not possible to define variables within a calculated field? I'm
> trying this simple declaration with no luck. First time attempting this.
> Define Variable x As Integer NO-UNDO.
> TIA,
> -Ted
> This e-mail and any attachments may contain proprietary and/or
> confidential information. If you are not the intended recipient, please
> notify the sender immediately by reply e-mail or at 410-472-2900 and
> then delete the message without using, disseminating, or copying this
> message or any portion thereof. With e-mail communications you are urged
> to protect against viruses.
Is it not possible to define variables within a calculated field? I'm trying this simple declaration with no luck. First time attempting this.
TIA,
-Ted
Good Day Ted:
I do not think so - not directly.
I have never done it, but you could define a parameter either in the
Display>>filter screen OR the Phrase-Build tab>>Criteria tab. It
might then let you put that Parameter in a Calculated field. I doubt it
though.
Len
Of tkoch77
TIA,
-Ted
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Brian.
Of tkoch77
TIA,
-Ted
Good Day Brian:
len.hartka@...
Of Brian Roberts
Brian.
Behalf
Of tkoch77
TIA,
-Ted
Brian.
Of Len Hartka
Good Day Brian:
Behalf
Of Brian Roberts
Brian.
Behalf
Of tkoch77
TIA,
-Ted
It worked for me.
Ephraim Feldman
Brian.
Of Len Hartka
Good Day Brian:
Behalf
Of Brian Roberts
Brian.
Behalf
Of tkoch77
TIA,
-Ted
