BAQ calculated field problem
adamtuliper,
I have often had luck using the opposite logic with outer join issues as
well as date issues. Instead of comparing to a blank, try to use a not and
compare to a real expression.
For instance...
(NOT RcvDtl.ReceiptDate > 01/01/1990)
The code might not be accurate above, but maybe this will give you an idea
that helps lead to a solution.
Sometimes it also works to compare to a real date with a <...
(RcvDtl.ReceiptDate < 01/01/1990)
Might work also.
These are just off the cuff guesses first thing on a Monday, so I hope
something useful can be gained.
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
adamtuliper
Sent: Sunday, January 07, 2007 5:01 AM
Subject: [Vantage] Re: BAQ calculated field problem
doh... I was almost there, it is the ="" causing the issue...
this works: (If (PoRel.DueDate<RcvDtl.ReceiptDate) Or (PoRel.DueDate
< TODAY ) then "Late" else "On-time")
however the (RcvDtl.ReceiptDate = "") from below is failing since Im
outer joining and that RcvDtl record doesn't exist, so I need a "null
check" as the ="" isn't working - any thoughts?
--- In vantage@yahoogroups.com, "adamtuliper" <amt@...> wrote:
> Im trying to find a reference of valid functions.
> the report builder reference for progress didnt help
> http://www.psdn.com/library/servlet/KbServlet/download/1070-102-
> 878/rbu.pdf
> as Im not surprised since its for progress report builder but had
hoped
> to have same methods available in a calcd field.
> I'm essentially trying an expression like the following and can't
seem
> to get today's date to compare against (and is the ="" check valid
as
> well for a null date field?):
> (If (PoRel.DueDate<RcvDtl.ReceiptDate) Or (PoRel.DueDate< Today()
And
> RcvDtl.ReceiptDate = "") then "Late" else "On-time")
> any link to a doc with valid functions in it?
878/rbu.pdf
as Im not surprised since its for progress report builder but had hoped
I'm essentially trying an expression like the following and can't seem
to get today's date to compare against (and is the ="" check valid as
(If (PoRel.DueDate<RcvDtl.ReceiptDate) Or (PoRel.DueDate< Today() And
> 878/rbu.pdf
hoped
seem
as
And
