I’m trying to create a calculated field of type bit that is true if a column is not null and false if it is null. What’s the correct syntax?
I simplified it to a BAQ with just one table, Part, and tried the obvious, Part.PartNum is not null. This produces an error, “Invalid syntax near keyword ‘as’.” That’s not a typo.
If I enter a literal 1 in the expression editor, it accepts the syntax.
