Hi All,
I’d like to count the number of approved revs via a BAQ. I created a calculated field and used the count function to count PartRev.approved, but found that tells me the total number of revs. How can I count the number of approved revs?
Hi All,
Try SubQuery Criteria
Try a sum instead.
Sum(PartRev.Approved)
If that doesn’t work (but field error), then try:
Sum(case when PartRev.Approved = 1 then 1 else 0 end)
noticed this was E9. sorry if this doesn’t work for you instance.
approved revs total?
select count (*)
from erp.PartRev as pr
where pr.approved = 1
approved by part?
select pr.PartNum, count (*)
group by pr.PartNum
