No. I've heard of some improvements in 9 (like being able to join a table multiple times) but have no idea if Calc fields can be used w/ criteria to limit returned results.
--- Original Message ---
Sent:Thu 9/16/10 12:45 pm
To:<vantage@yahoogroups.com>
Subj:RE: [Vantage] BAQ Calc. Field as Query Criteria
Are you insinuating that this is possible in 9x?
Of robertb_versa@...
Sent: Thursday, September 16, 2010 12:12 PM
Subject: Re: [Vantage] BAQ Calc. Field as Query Criteria
Not in 8.03.4XX.
From:"Mike" <mikeyto_96@... <mailto:mikeyto_96%40yahoo.com> >
Sent:Thu 9/16/10 11:23 am
To:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Subj:[Vantage] BAQ Calc. Field as Query Criteria
Is it possible to use a BAQ calculated field as a criteria field in the
same BAQ? If so, which table would the calc field be located in?
Thank you in advance for you help!
Not in 8.03.4XX.
