BAQ Bad SQL Statement from Table Criteria
I have a fairly simple BAQ that is returning a Bad SQL Statement error when testing it. I have criteria set on my InvcDtl table for PartNum <> 123 constant (123 being subbed out for the real PartNum in this example) AND PartNum <> 1234 constant (Again 1234 being subbed out for the real PartNum in this example). When I remove these the BAQ runs and returns data, which it should return data with or without these criteria.
I also have criteria on the Customer table for CustID = Cust1 constant (Cust1 being subbed for real customer name in this example). When I remove just this criteria the BAQ runs even when leaving the criteria on the InvcDtl table.
I checked the calculated field and it is not affecting this in any way. My links are also correct. I am stuck on this for now and I am not sure if this is a bug in Epicor 10.2.300.13 or if there is something going on in the background that I am unaware of.
Here is my Code:
select
[InvcHead].[InvoiceDate] as [InvcHead_InvoiceDate],
[InvcHead].[InvoiceNum] as [InvcHead_InvoiceNum],
[InvcDtl].[DocExtPrice] as [InvcDtl_DocExtPrice],
[InvcDtl].[DocDiscount] as [InvcDtl_DocDiscount],
[InvcDtl].[DocTotalMiscChrg] as [InvcDtl_DocTotalMiscChrg],
((InvcDtl.DocExtPrice) - (InvcDtl.DocDiscount) + (InvcDtl.DocTotalMiscChrg)) as [Calculated_LineTotal],
[ShipTo].[Name] as [ShipTo_Name],
[ShipTo].[Address1] as [ShipTo_Address1],
[ShipTo].[City] as [ShipTo_City],
[ShipTo].[State] as [ShipTo_State],
[ShipTo].[ZIP] as [ShipTo_ZIP],
[Customer].[CustID] as [Customer_CustID],
[InvcDtl].[XPartNum] as [InvcDtl_XPartNum],
[InvcDtl].[PartNum] as [InvcDtl_PartNum],
[InvcDtl].[OTSState] as [InvcDtl_OTSState],
[InvcDtl].[SellingShipQty] as [InvcDtl_SellingShipQty]
from Erp.InvcHead as InvcHead
inner join Erp.InvcDtl as InvcDtl on
InvcHead.Company = InvcDtl.Company
and InvcHead.InvoiceNum = InvcDtl.InvoiceNum
and ( InvcDtl.PartNum <> ‘123’ and InvcDtl.PartNum <> ‘1234’ )
inner join Erp.ShipTo as ShipTo on
InvcDtl.Company = ShipTo.Company
and InvcDtl.CustNum = ShipTo.CustNum
and InvcDtl.ShipToNum = ShipTo.ShipToNum
inner join Erp.Customer as Customer on
InvcHead.Company = Customer.Company
and InvcHead.CustNum = Customer.CustNum
and ( Customer.CustID = ‘Cust1’ )
where (InvcHead.Posted = TRUE)
Here is my calculated field if you need it (It is a Decimal with the format: ->>>,>>>,>>9.99):
What does the error read?
The quotes around your parts and custid don’t look right. In a BAQ, you don’t need to add them (if you did).
I would expect your criteria to appear in the SQL after a “where”, but they look like join conditions here.
Are you entering those in the criteria details for each table in the BAQ designer?
Hi Joshua,
One thing sticks out in your BAQ for me. It’s using the ShipTO table. I have struggled with this table in queries since we went on Epicor. For a Cust Num, Ship to num can be blank. Is it possible that the join on the InvcDtl.Ship to num to ShipTo.ShipToNum is your problem?
Nancy
The link from InvcDtl.ShipToNum to ShipTo.ShipToNum seems to be causing my issue. Thank you!
