BAQ Aggregate of Updatable Aggregate
Hello all - I’m new to Epicor and struggling to understand aggregates in BAQ’s. I have an updatable baq used in a dashboard that allows our project managers to fill in the completion of a project as a percentage. What I’m trying to do is get an overall completion average of all projects.
I summed up the updated field called “percentcomplete”, I’ve done a count of all projects called “count_projs”. What I need to do now is basically percentcomplete/count_projs to get the average. I can’t do this since both are aggregates and can’t be used in formulas from what I’m seeing. The information on subqueries is totally unhelpful - I can’t really find if this is my answer or how it would work with my updatable percentcomplete field. Any help is greatly appreciated!
Welcome @TinaK !
Are you trying to calculate this field in a BAQ separate from the UBAQ?
This is all in the same updatable baq if that’s what you’re asking me.
Yes, that was what I was asking. I’m not sure if this would work, but I would try an OVER clause to get what you need.
I actually need to get the max of both the percent complete and project count and use those to get my overall average. My apologies, I left that part out of my original question. Trying to do a max of an aggregate gives me the “Windows functions cannot be used in the context of another windowed function or aggregate” error
@TinaK Since this is already updatable if you are comfortable with C# you can do the calculation post processing on getlist.
