Bank Adjustment not showing in Bank Reconciliation
We are recently upgraded and since have found a bank adjustment entry that is not showing up in the Bank Reconciliation module. This entry is an adjustment between two banks (instead of using bank transfer) we have used bank adjustment previously with no issues. We can see the transactions posting to both of the related Gl accounts however, the transaction is stuck and does not appear in the bank rec to clear.
In our test environment, we can recreate this. Is this a known issue? Is there a patch or script to run that can fix it?
Lori,
Did you receive a solution to this problem? We are having the same issue.
Mason
Sorry Mason to tell you there was no response.
We ended up undoing the adjustment and posting through the bank transfer option. Thankfully this fixed our concern and the transaction showed in the bank reconciliation.
Best of luck
Lori
