BAM or Method Directive For E-Mail Alerts
Got it, Thanks Rob
--- On Mon, 4/13/09, Rob Bucek <rbucek@...> wrote:
Subject: RE: [Vantage] BAM or Method Directive For E-Mail Alerts
Date: Monday, April 13, 2009, 11:19 AM
You need to create it. Open up notepad, paste that code in there,
substitute the table and field names where appropriate and save it as
some name with a '.p' file extension in your Epicor directory
<your server>\mfgsys803\ Server.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg com/>
(Click the logo to view our site)
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Mark Wagner
Sent: Monday, April 13, 2009 10:16 AM
To: vantage@yahoogroups .com
Thanks Rob, I was looking at this option but wasnt sure if I needed to
create it or if the program was already there to attach as an Alert
Program?
--- On Mon, 4/13/09, Rob Bucek <rbucek@dsmfg. com
<mailto:rbucek% 40dsmfg.com> > wrote:
From: Rob Bucek <rbucek@dsmfg. com <mailto:rbucek% 40dsmfg.com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Date: Monday, April 13, 2009, 11:04 AM
Attach a .p program to the bam that will lookup and include the values
from the table you are monitoring. Some individual wiser than I gave an
example of this on the thread and it worked in a very cool fashion.
Rob Bucek
FAX: 715-284-4084
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
Of Mark Wagner
Sent: Monday, April 13, 2009 9:53 AM
To: Vantage User Group
Subject: [Vantage] BAM or Method Directive For E-Mail Alerts
I'm triggering e-mails based on certain Task IDs in Case Entry. Is there
a way I can include key fields such as Task ID, Case Number, etc in the
e-mail using the BAM or do I need to use a method directive?
I'm triggering e-mails based on certain Task IDs in Case Entry. Is there a way I can include key fields such as Task ID, Case Number, etc in the e-mail using the BAM or do I need to use a method directive?
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/>
Of Mark Wagner
I dug up the example.
{ud/GlbAlert.i &TableName = "JobHead"}
Assign Email-Text = "Job Number: " + string(JobHead.JobNum)
+ "~nPart Number: " + string(JobHead.PartNum)
+ "~nRevision: " + string(JobHead.Revision).
Credit goes to Steven Gotschall who I believe provided this example..
Rob Bucek
FAX: 715-284-4084
Of Mark Wagner
Thanks Rob, I was looking at this option but wasnt sure if I needed to create it or if the program was already there to attach as an Alert Program?
Rob Bucek
FAX: 715-284-4084
Of Mark Wagner
<your server>\mfgsys803\Server.
Rob Bucek
FAX: 715-284-4084
Of Mark Wagner
Program?
<mailto:rbucek%40dsmfg.com> > wrote:
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
Rob Bucek
FAX: 715-284-4084
Behalf
Of Mark Wagner
