Looks like your file association is messed up. The link file (*.vdl)
should be associated with the VantageEmailLink program. This program
should be located in your mfgsys61\dll folder.
Butch
Sent: Friday, February 18, 2005 12:47 PM
Subject: RE: [Vantage] Re: BAM - Email Alerts - 6.10 (& Global Alerts)
Whenever we open the attachment - it opens notepad (aaarrgh!)
PS - Watch out for 6.10.521 - after we installed it some of our part
numbers changed in our orders. When the parts were created they were
fine - sales has hard copies to prove it. After 521 was installed the
system placed a number "3" in the front of the part number in the S/O. I
didn't know about it until I was looking at some jobs which had part
numbers I knew shouldn't be in the system. These parts were all placed
in the S/O using the COPY FROM procedure so we're pretty sure it must be
linked. None of the other parts, which were configured, changed.
Sue
Sent: Friday, February 18, 2005 5:37 AM
Subject: [Vantage] Re: BAM - Email Alerts - 6.10 (& Global Alerts)
One other comment on BAM e-mail alerts. We are using it to alert A/R
when someone changes the credit status of a customer. There is a
check box on the BAM Maintenance screen to Included Link. If you
check that box the e-mail alert includes an attachment, which will
open up Customer Tracker for the affected customer. I haven't tried
the alert program option, but the include link my be useful for some
of you.
Brian Stenglein
Clow Stamping Co.
Butch
Sue
of you.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> I think this got missed in the Port / TS issue. As for the "what"
I implemented one of the samples in the UD/TEST folder (under
mfgsys61 for us) and it works really nice. When I got the email
working the first thing the user said was "OK, I know someone changed
a customer address....which customer?" There was a sample .p routine
for just this situation plus several other sample routines. Any could
be modified for most tables and keys. Then you put the routine in
the BAM field for Alert Program. Now in addition to the alert text
(what was changed) it displays "who" was changed.
> -Todd
> From: Susan Iverson [mailto:siverson@j...]
> Sent: Wednesday, February 16, 2005 3:39 PM
> Subject: RE: [Vantage] BAM - Email Alerts - 6.10 (& Global Alerts)
> Another question - now that I know how to set these up, does anyone
know
> how (in BAM) you can get it to tell you "what" has changed - so far
some
> will tell you and some won't (i.e., "part number has changed" but it
> doesn't tell you "what" part number).
> Thank you!
> Sue
> From: Butch Menge [mailto:bmenge@t...]
> Sent: Monday, February 14, 2005 2:34 PM
> Note that you don't have to run the process server on the server,
it can
> be run on any PC with Vantage installed. I run it from my desktop
> system because it allows me to easily check on it (I've had it hang
> several times sending e-mail).
> The alerts are stored in a table called AlertQue if you need to see
how
> many messages are in the queue and where they are going.
> Butch
> Sent: Monday, February 14, 2005 2:14 PM
> 1. You have to have Email configured in Vantage Company
> Configuration with correct port numbers (I still have not been able
to
> find a Vantage port that doesn't give us an "already being used"
error
> message but it still works)..
> 2. Start Process Server.MFG on the server console (it's in
mfgsys61
> folder) and LOCK THE CONSOLE - once you log off it stops the
service.
> Make sure the edited Process Server.MFG has the correct server name,
> etc.
> 3. Setup a "from" address on your email server and use it as
the
> sender when setting up alerts.
> 4. Look-out because it's going to pick up every transaction and
> begin sending out a ton of email - run a test to your inbox first.
> Sue
> From: Todd Caughey [mailto:caugheyt@h...]
> Sent: Monday, February 14, 2005 1:26 PM
> I don't see any services ont he email server named "Process
Server" -
> started or not. Gotta run to the eye doctor now but a gentle hint
at
> where to find it and start it tomorrow morning would be much
> aprpeciated.
> Thanks,
> -Todd C.
> From: Lepley, Scott A. [mailto:sal@m...]
> Sent: Monday, February 14, 2005 3:21 PM
> Todd,
> You must have Process Server running to process the email
messages. Do
> you
> have that running?
> Regards,
> Scott Lepley
> Systems Administrator
> Mauell Corporation
> Phone: 717-432-8686, ext. 14
> Fax: 717-432-8688
> Email: sal@m...
> Vantage version: 6.10.518
> Sent: Monday, February 14, 2005 4:08 PM
> Subject: [Vantage] BAM - Email Alerts - 6.10
> I thought this had been discussed from time to time but can't find
it in
> my
> archived messages. What exactly has to be done to make the Business
> Activity Manager send email. I have one setup to log changes to
> customer
> addresses and would like to have it send an email message to a key
user
> who
> is responsable for keeping the custoemr data correct. I have set
the
> Company email settings but am unlear as to the port numbers (from
prior
> messages am using 5679 and 25). Just to start with the sending
> address I am using is Administrator@.... - I will probably create a
> special account sometime after getting it to work.
> Is there a service or something that needs to be turned on? Right
now
> nothing happens at all - no errors or messages, just no email
message.
> The
> help screens are pretty worthless for explaining anything or having
> examples.
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> < http://groups.yahoo.com/group/vantage/files/>
> Yahoo! Groups Sponsor
> ADVERTISEMENT
http://us.ard.yahoo.com/SIG=1299pjo3l/M=298184.6018725.7038619.3001176
D=groups/S=1705007183:HM/EXP=1108502454/A=2532114/R=2/SIG=12kf9om4u/*h
tt
p://clk.atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=1108416
05
> 4331884
tt
p:/clk.atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=11084160
54
> 331884> >
> < http://us.adserver.yahoo.com/l?
M=298184.6018725.7038619.3001176/D=group
> s/S=:HM/A=2532114/rand=211749450>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service < http://docs.yahoo.com/info/terms/> .
must
access. )
Builder
> ADVERTISEMENT
http://us.ard.yahoo.com/SIG=129vd6spr/M=298184.6018725.7038619.3001176
D=groups/S=1705007183:HM/EXP=1108502820/A=2532114/R=2/SIG=12kpjnnad/*h
tt
p:/clk.atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=11084164
20
> 523372>
> < http://view.atdmt.com/NFX/view/yhxxxnfx0020000014nfx/direct/01/
<http://view.atdmt.com/NFX/view/yhxxxnfx0020000014nfx/direct/01/&time=
11> &time=11
> 08416420523372>
> s/S=:HM/A=2532114/rand=675130779>
> _____
> Yahoo! Groups Links
of
must
access. )
Builder
> ADVERTISEMENT
http://us.ard.yahoo.com/SIG=129bik9f3/M=298184.6018725.7038619.3001176
D=groups/S=1705007183:HM/EXP=1108505626/A=2532114/R=2/SIG=12kmgf9q6/*h
tt
p://clk.atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=1108419
22
> 6542210>
> s/S=:HM/A=2532114/rand=675577004>
> Yahoo! Groups Links
must
access. )
Builder
> ADVERTISEMENT
http://us.ard.yahoo.com/SIG=129roj2k4/M=298184.6018725.7038619.3001176
D=groups/S=1705007183:HM/EXP=1108506857/A=2532114/R=2/SIG=12kpsje6i/*h
tt
p:/clk.atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=11084204
57
> 213025>
11> &time=11
> 08420457213025>
> s/S=:HM/A=2532114/rand=814973919>
> _____
> Yahoo! Groups Links
of
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129nbr1k5/M=298184.6018725.7038619.300117
6/D=groups/S=1705007183:HM/EXP=1108676317/A=2532114/R=2/SIG=12k9coe69/
*http://clk.atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=110
8589917490850>
> <http://us.adserver.yahoo.com/l?
M=298184.6018725.7038619.3001176/D=groups/S=:HM/A=2532114/rand=9610251
04>
> _____
> Yahoo! Groups Links
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
Service <http://docs.yahoo.com/info/terms/> .
_____
Yahoo! Groups Links
Yahoo! Groups Links
