BAM e-mail notification (not)
thanks Butch and Patrick.
with your help, this procedure works as expected. It turns out that I
had a blank
in the "from" e-mail address in the BAM. When that is blank, nothing
happens.
Again, thank you for your help.
kind regards,
I have this script attached to a BAM global that only fires for
partnumber s-0167.
can anyone see where the problem lies?
{ud/GlbAlert.i &TableName = "RcvDtl"}
DEFINE VARIABLE NewEmailBody AS CHARACTER NO-UNDO.
FIND part WHERE RcvDtl.Partnum = 's-0167' NO-LOCK NO-ERROR.
IF RcvDtl.PartNum = 's-0167'
THEN DO:
ASSIGN Email-Text = "Receipt Information - ~n~n"
+ "PONum " + STRING(Mfgsys.RcvDtl.PoNum) + "~n"
+ "POLine " + STRING(Mfgsys.RcvDtl.PoLine) + "~n"
+ "PackSlip " + STRING(RcvDtl.PackSlip).
FIND part WHERE RcvDtl.PartNum = 's-0651' NO-LOCK NO-ERROR.
IF RcvDtl.PartNum = 's-0651'
THEN DO:
+ "PO Num " + STRING(Mfgsys.RcvDtl.PoNum) + "~n"
+ "PO Line " + STRING(Mfgsys.RcvDtl.PoLine) + "~n"
+ "PackSlip " + STRING(Mfgsys.RcvDtl.PackSlip).
IF RcvDtl.PartNum <> 's-0167' or RcvDtl.PartNum <> 's-0651'
THEN RETURN "Cancel Send":U.
END.
END.
mucho gracias~
I am a BAM newbie myself, but try changing your "or" to "and".
With "or", one of the two scenarios is always true, so the email is
canceled.
Michael Randolph
Purchasing Manager
American Magnetics, Inc.
--- In vantage@yahoogroups.com, "PLAMAN DICK" <dick.plaman@T...>
> partnumber s-0167.
> THEN DO:
> THEN DO:
+ "~n"
> END.
> END.
> mucho gracias~
Dick,
In addition to the And/or problem noted by Michael the line above will not
provide any benefit.
You are asking to find a part master file where a contrition unrelated to
the part master exists.
If you would like to find the Part record for the RcvDtl your line should
look more like:
FIND Part WHERE Part.Company = RcvDtl.Comapany AND
Part.PartNum = RcvDtl.PartNum NO-LOCK NO-ERROR.
Then you will be able to use information from the part table.
If you do not need information from the part table, the line can and should
be eliminated.
Good luck,
Aaron Hoyt
Vantage Plastics
Sent: Thursday, March 10, 2005 11:00 AM
Subject: [Vantage] Re: BAM e-mail notification (not)
canceled.
Michael Randolph
Purchasing Manager
> partnumber s-0167.
> THEN DO:
> THEN DO:
+ "~n"
> END.
> END.
> mucho gracias~
Yahoo! Groups Links
Thanks Michael and Aaron,
i took your advice but now I can't get anything to happen.
this friggin' thing can be very frustrating (especially when I don't
know
that the &%$# I'm doing) The global alert broker is running, I have this
procedure
pegged to a valid e-mail address. There are no global alert errors.
can you see a problem with this code? or does anyone have a cyanide pill
they can spare?
IF RcvDtl.PartNum = 's-0167' THEN DO:
FIND part WHERE part.company = RcvDtl.Company and
part.partNum = RcvDtl.PartNum NO-LOCK NO-ERROR.
IF RcvDtl.PartNum = 'S-0167' /* I took this statement out, but no
difference: */
THEN DO:
ASSIGN Email-Text = "Receipt Information "
+ STRING(RcvDtl.OurQty)
+ STRING(RcvDtl.PartNum).
IF RcvDtl.PartNum = 'S-0651' THEN DO:
THEN DO:
END.
END.
ELSE DO:
END.
END.
ELSE DO:
END.
END.
Dick.
Try this:
ASSIGN Email-Subject = 'Receiving part S-0167 by ' + USERID.
ASSIGN Email-Text = 'For Receipt Information click on the attachment'.
END.
ELSE DO:
RETURN ERROR.
END.
Also check the check box in BAM to "include link". The person receiveing the
email should be able to click on the link and bring up the receipt.
Patrick Winter
Sent: Thursday, March 10, 2005 2:49 PM
Subject: RE: [Vantage] Re: BAM e-mail notification (not)
this friggin' thing can be very frustrating (especially when I don't know
procedure pegged to a valid e-mail address. There are no global alert
errors.
they can spare?
difference: */
THEN DO:
THEN DO:
END.
END.
ELSE DO:
END.
END.
ELSE DO:
END.
END.
Yahoo! Groups Links
Try this as a starting point:
IF (RcvDtl.PartNum = "s-0167") or (RcvDtl.PartNum = "S-0651") THEN DO:
FIND part WHERE part.Company = RcvDtl.Company and
part.PartNum = RcvDtl.PartNum NO-LOCK NO-ERROR.
ASSIGN Email-Text = "Receipt Information " + "~n"
+ "PO Number: " + STRING(Mfgsys.RcvDtl.PoNum) + "~n"
+ "PO Line: " + STRING(Mfgsys.RcvDtl.PoLine) + "~n"
+ "Packslip: " + STRING(RcvDtl.PackSlip) + "~n"
+ "Our Qty: " + STRING(RcvDtl.OurQty) + "~n"
+ "Part Number: " + STRING(RcvDtl.PartNum).
ASSIGN Email-Subject = RcvDtl.PartNum + " has been received".
ASSIGN Email-To = "EmailAddress@...".
END.
ELSE DO:
END.
Butch
Sent: Thursday, March 10, 2005 12:49 PM
know
procedure
they can spare?
difference: */
THEN DO:
THEN DO:
END.
END.
ELSE DO:
END.
END.
ELSE DO:
END.
END.
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129d3jvkr/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1110574157/A=2593423/R=0/SIG=11el9gslf/*htt
p://www.netflix.com/Default?mqso=60190075>
<http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=group
s/S=:HM/A=2593423/rand=782919721>
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
