I uploaded POReleaseSuspenseReminder.P. It fires off the PORel.ExpChart
field.
Butch
Sent: Monday, February 28, 2005 5:39 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] BAM Class 101 - remedial help
I'm using it for new parts, too, so that inventory control has an
opportunity to validate the time-phase-related characteristics as soon
as a
part is created. I've also created BAM alerts for new orders (to notify
engineering admin), new job headers (to notify the job planner) and new
vendors (to notify quality control). So far, personnel responses have
been
mostly positive. Would you mind posting your BAM for PO releases
pointing
to a suspense account to our group file section?
In order for the line feed/carriage return to work properly, must the ~n
be
included in quotes?
Regards,
Scott
Sent: Saturday, February 26, 2005 12:58 AM
Glad it helped Scott. I use that feature to send notifications/messages
of new part additions, new requisitions (notify the approver that they
need to check their to do list), etc. I recently wrote a BAM to display
a message to the user if the PO Rel line GL Chart is pointing to a
suspense account.
I'm sure someone will know the true meaning of the U function but the ~n
causes a Line Feed Carriage Return.
Butch
Sent: Friday, February 25, 2005 2:10 PM
Thanks Butch and Patrick for your replies. Butch, your reply did the
trick;
as I figured, it was quite simple. I had already limited the BAM to the
RMANum field only, but I was thinking that I still needed to specify a
selection condition in the alert program. The moment I read your reply,
it
finally dawned on me that I was already setting the condition by
monitoring
only that particular field. Doh!
Now I have another couple of questions. Has anyone else seen the body
of
global alert messages NOT changing even though the text specified in the
alert program (.p) was changed? Can someone explain the functions of
"U"
and "~n"?
Regards,
Scott
Sent: Wednesday, February 23, 2005 4:21 PM
One option would be to fire the BAM on the field RMANum in the RMAHead
table (only select that field). That RMANum field should only be
modified once - when it is created.
Butch
Sent: Wednesday, February 23, 2005 12:20 PM
OK, I am right there with Michael with these BAM's. Creating them and
configuring them to append log text and attach alert.vdl files has
worked
pretty well (the exceptions being those tables for which Vantage will
not
attach an alert.vdl). However, trying to write alert programs has been
a
completely different matter, even with Epicor's sample .p files; not one
has
worked yet.
This may be very simple, but I'm just not seeing it. Can someone
suggest to
me how to look for only new records, e.g. new RMA's, and send an alert
when
they are entered?
Regards,
Scott Lepley
Systems Administrator
Mauell Corporation
Phone: 717-432-8686, ext. 14
Fax: 717-432-8688
Email: sal@...
Vantage version: 6.10.518
Sent: Monday, February 21, 2005 10:33 AM
Michael,
Try ending your if after the not available.
and also end the else statement at the end.
I would also assign the email "to" with an email address within the .p
to be
safe.
If I am not mistaken, your logic is missing the second if statement
unless
the Part table is not available, the opposite of what you are looking
for.
Also, I don't believe you need to call out the full name of Mfgsys.Part,
just Part should do, the database is assumed.
I suspect this will fix most of the problems.
For instance:
{ud/GlbAlert.i &TableName = "RcvDtl"}
FIND Part WHERE Part.PartNum = RcvDtl.PartNum
NO-LOCK NO-ERROR.
IF NOT AVAILABLE Part THEN RETURN "Cancel Send":U.
END.
IF (Part.Mtl-AnalysisCode = "ECN":U) THEN DO:
ASSIGN Email-Subject = "ECN Critical Item"
Email-To = "insert the email address here".
END.
ELSE RETURN "Cancel Send":U.
END.
Good luck,
Aaron Hoyt
Vantage Plastics
Sent: Monday, February 21, 2005 10:17 AM
Subject: [Vantage] BAM Class 101
OK folks, I need some help with my first BAM. It is simple, but I
can't get it to work. What I want is to send an alert when a part
is received that has a specific Material Analysis Code in the Part
table. The code in question is "ECN". (We are trying to improve
part of our ECN process.)
What I have written (copying from the samples) is:
FIND Mfgsys.Part WHERE Mfgsys.Part.PartNum = Mfgsys.RcvDtl.PartNum
NO-LOCK NO-ERROR.
IF NOT AVAILABLE Mfgsys.Part THEN RETURN "Cancel Send":U.
IF (Mfgsys.Part.Mtl-AnalysisCode = "ECN":U) THEN DO:
ASSIGN Email-Subject = "ECN Critical Item".
END.
I have worked on this until I no longer get any errors, but I still
don't receive the email. Any suggestions for a Progress newbie?
Perhaps the code is OK, but I am doing something wrong on the BAM.
Michael Randolph
Purchasing Manager
American Magnetics, Inc.
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129gdo6u1/M=298184.6018725.7038619.3001176/
D=groups/S=1705007183:HM/EXP=1109684342/A=2593423/R=0/SIG=11el9gslf/*htt
p://www.netflix.com/Default?mqso=60190075>
<http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=group
s/S=:HM/A=2593423/rand=237600894>
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
field.
Butch
as a
been
pointing
be
included in quotes?
Regards,
Scott
suspense account.
Butch
trick;
it
monitoring
of
"U"
and "~n"?
Regards,
Scott
Butch
worked
not
a
has
worked yet.
suggest to
when
they are entered?
Regards,
Scott Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
Michael,
to be
safe.
unless
for.
For instance:
NO-LOCK NO-ERROR.
END.
END.
END.
Good luck,
Aaron Hoyt
Vantage Plastics
NO-LOCK NO-ERROR.
END.
Michael Randolph
Purchasing Manager
ADVERTISEMENT
click here
Yahoo! Groups Links
