OK here is one way I do the autoprint of Shop Dispatch Report.
Create a new user called something other than "Reports".. funny story, I created a user called "Reports" then tried to print and it just kept crashing. Seems it was building a string path for the report .xml but since it was called "Reports" and the folder the report is in is also called "Reports" it kacked out with \reports/reports. Probably the only person to ever do this...
Anyway, once you create a new user, give them only permissions to run the report(s) you need. Then set up a recurring daily schedule for say 6:00AM in your System Agent.
Now set up a new Epicor Icon and a new .mfgsys that is linked to the Icon with the Autologon Username and Password set in the .mfgsys
Now log-in to Epicor as this new user, launch the Shop Dispatch Report and print it to the preferred printer but use the Scheduled Report options to submit it on the new schedule at 6:00AM.
Exit Epicor.
Next, set the Windows Task Manager to launch the new Epicor Icon at 7:00AM and the system will launch your new Epicor app with the new .mfgsys autologon for the new user and print out the generated report because it automatically prints out missed reports when you login.
Hope this helps someone.
Regards,
George Hicks
Pacific Consolidated Industries
Exit Epicor.
Regards,
George Hicks
