BAM and .P File
I have a couple in the BAM file section and use a lot of them, so I may have already written one you can use. what table are you alerting on?
you can set sendmail = true or false based on conditions in the .p and you may be able to set rules before that to filter. You only want the fields that you want alerts on or rules set for in the included list of the bam.
Below is from the thread Request for basic Help from last month.
Greg Payne
There is a BAM example I made for OrderRel in the file section under BAM folder.
The link below has the basics of how to add the .p procedure to a BAM. I used it when I first started using BAM custom emails.
http://f1.grp.yahoofs.com/v1/1FiBUdVcmahNmtCh_R3mI0-z03nhmnNlpxW3_qJoqwjPzw9qyT2xC1zZSNEotCef4lC5NDTo1fW_C_FZeX4Yp5aCjzcFiseBXMkCMwRDbpqr6hd9/BAM_Alert_OrderRel_DropShip.zip
If you use the release need by then you can reference the partnum, etc to make the email complete.
Let me know if you have any specific coding questions.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of De Anna Mirzadegan
Sent: Monday, June 10, 2013 6:50 PM
Subject: [Vantage] BAM and .P File
Hello Everyone -
I was wondering if someone could help me with BAMs. I have very simple ones
set up as I don't know how to do much with the .P file.
One problem I am having is that I have a BAM set up to notify me when a new
part or a new quote is entered. However, it notifies me every time there is
any change to it. Does anyone know how to fix this?
Does anyone have any .P files they are willing to share? I don't know how
to write them myself, but I am good at taking something and editing to what
I need.
De Anna Mirzadegan
Epicor 9.05.700c
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Hello Everyone -
I need.
De Anna Mirzadegan
Epicor 9.05.700c
