[Resending this from early September in case this is useful to you. -bws]
Here's what I wound up doing:
1. Save the below 4GL code API-POApprovalNotification.p as a .P file under mfgsys803\server\ud\ with whatever name you want.
2. Create a BAM on POHeader watching for changes in ApprovalStatus and ShortChar01. Add rules, For Alert, where ApprovalStatus <> U or ShortChar01 <> "".
3. Create a BPM as follows:
- POApvMsg.Update, Post-Processing
- Condition: Number of Rows in 'GetApvMsg' query is not lets than one
- Query: for each ttPOApvMsg where ttPOApvMsg.MsgType = '1' no-lock
- Action: Synchronously execute 4GL Action with code below, record nothing
- Code:
find ttPOApvMsg.
for each ttPOApvMsg no-lock:
message "ttPOApvMsg.PONum: " + string(ttPOApvMsg.PONum) + "~n".
find first POHeader where POHeader.Company = ttPOApvMsg.Company and POHeader.PONum = ttPOApvMsg.PONum no-lock.
define variable ApprovalChain as character no-undo.
ApprovalChain = POHeader.ShortChar01 + "/" + ttPOApvMsg.MsgTo.
run lib\UpdateTableBuffer.p(input BUFFER POHeader:HANDLE, 'ShortChar01',ApprovalChain).
end.
That's it.
The point here is that without the BPM you have no way that I could figure out how to detect when the up-level approval notification has been generated, so you'd only get an e-mail from the BAM from the initial PO approval request, not the subsequent ones. With the BPM I modify a ShortChar field in the POHeader table appending the next approver. The data is irrelevant, as long as the field changes, and thus the BAM gets triggered. This notification program sends e-mail to each approver in series (assuming their Buyer record has an e-mail address), and the requestor Buyer indicating the final disposition (approve or reject) of the PO approval request.
I needed to use a BAM because I didn't think one could use a BPM 4GL action to send e-mail. However I saw something about this come across the list recently (although I apparently didn't save it and given how badly the search works in this Yahoo! Group not sure if I can find it again), so I think you could do this entirely as a BPM if you wanted to keep it cleaner. It seems to me that one should be able to do everything in a BPM that one can do in a BAM.
-bws
-----Begin API-POApprovalNotification.p-----
{ud/GlbAlert.i &TableName = "POHeader"}
DEFINE VARIABLE POAmount AS DECIMAL NO-UNDO.
DEFINE VARIABLE PONumber AS DECIMAL NO-UNDO.
DEFINE VARIABLE Company AS CHARACTER NO-UNDO.
DEFINE VARIABLE ApprovalStatus AS CHARACTER NO-UNDO.
DEFINE VARIABLE ApproverEmail AS CHARACTER NO-UNDO.
DEFINE VARIABLE ApproverName AS CHARACTER NO-UNDO.
DEFINE VARIABLE ApproverCode AS CHARACTER NO-UNDO.
DEFINE VARIABLE RequestorEmail AS CHARACTER NO-UNDO.
DEFINE VARIABLE RequestorName AS CHARACTER NO-UNDO.
DEFINE VARIABLE RequestorCode AS CHARACTER NO-UNDO.
DEFINE VARIABLE StatusText AS CHARACTER NO-UNDO.
DEFINE VARIABLE ApprovalStatusDesc AS CHARACTER NO-UNDO.
PONumber = POHeader.PONum.
Company = POHeader.Company.
ApprovalStatus = POHeader.ApprovalStatus.
message "In API-POApprovalNotification.p: Company: " + Company + " PONumber: " + string(PONumber) + " ApprovalStatus: " + ApprovalStatus + "~r~n".
find PODetail where (PODetail.Company = POHeader.Company) and (PODetail.PONum = POHeader.PONum) no-lock no-error.
for each PODetail of POHeader:
POAmount = POAmount + (PODetail.DocUnitCost * PODetail.OrderQty).
end.
find POApvMsg where (POApvMsg.Company = POHeader.Company) and (POApvMsg.PONum = POHeader.PONum) no-lock no-error.
if available POApvMsg then do:
case POApvMsg.MsgType:
when "1" then do:
find PurAgent where (PurAgent.Company = POHeader.Company) and (PurAgent.BuyerId = POApvMsg.MsgTo) no-lock no-error.
ApproverName = PurAgent.Name.
ApproverEmail = PurAgent.EmailAddress.
ApproverCode = PurAgent.BuyerID.
find PurAgent where (PurAgent.Company = POHeader.Company) and (PurAgent.BuyerID = POApvMsg.MsgFrom) no-lock no-error.
RequestorName = PurAgent.Name.
RequestorEmail = PurAgent.EmailAddress.
RequestorCode = PurAgent.BuyerID.
end.
when "2" then do:
end.
end case.
case ApprovalStatus:
when "A" then do:
StatusText = "Has Been Approved!".
ApprovalStatusDesc = "Approved".
Assign Email-To = RequestorEmail.
end.
when "R" then do:
StatusText = "Has Been Denied!".
ApprovalStatusDesc = "Rejected".
end.
when "P" then do:
StatusText = "Requires Approval...".
ApprovalStatusDesc = "Pending Approval".
Assign Email-To = ApproverEmail.
Assign Email-CC = RequestorEmail.
end.
when "U" then do:
message "Not sending e-mail for ApprovalStatus = U".
Assign SendEmail = False.
end.
end case.
message "Email-To: " + Email-To + "~nEmail-CC: " + Email-CC.
Assign Email-To = "bspolarich@...".
Assign Email-CC = "bspolarich@...".
find Vendor where (Vendor.Company = POHeader.Company) and (Vendor.VendorNum = POHeader.VendorNum) no-lock no-error.
Assign Email-From = "vantage-alerts@...".
Assign Email-Subject = POHeader.Company + " Purchase Order Approval Status Notification".
Assign Email-Text = "Purchase Order " + string(POHeader.PONum) + " " + StatusText + "~r~n"
+ "----------~r~n"
+ "Company: " + POHeader.Company + "~r~n"
+ "Vendor: " + Vendor.Name + " (" + Vendor.VendorID + ")~r~n"
+ "PO Amount: " + TRIM(string(POAmount, "$>>>,>>>,>>9.99")) + "~r~n"
+ "Approval Status: " + ApprovalStatusDesc + "~r~n"
+ "Buyer: " + RequestorName + " (" + RequestorCode + ") <" + RequestorEmail + ">~r~n"
+ "PO Date: " + string(POHeader.OrderDate) + "~r~n"
+ "Approver: " + ApproverName + " (" + ApproverCode + ") <" + ApproverEmail + ">~r~n"
+ "Comments: ~r~n" + POHeader.CommentText + "~r~n".
if (POApvMsg.MsgText <> "") then do:
Assign Email-Text = Email-Text + "Approval Message Log: ~r~n" + POApvMsg.MsgText + "~r~n".
end.
message "Email-Text: ~n" + Email-Text.
end.
else do:
message "Not sending e-mail.~r~n".
return "Cancel Send".
end.
-----End API-POApprovalNotification.p-----
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of liss_c
Sent: Tuesday, December 08, 2009 3:31 PM
Subject: [Vantage] Re: BAM alert program
Hi Leonard,
Yes I guess you could use their tools. But for our business we need dedicated approvals from specific individuals. With Vantage tools the alert is sent to a generic person no matter the circumstances of the requirement. Maybe in Epicor 9 the tools have more functionality, but for Vantage 8.03.406A this is not a good rooute.
Lissette C.
- Code:
find ttPOApvMsg.
end.
That's it.
-bws
end.
when "1" then do:
end.
when "2" then do:
end.
end case.
when "A" then do:
end.
when "R" then do:
end.
when "P" then do:
end.
when "U" then do:
end.
end case.
+ "----------~r~n"
end.
end.
else do:
end.
Hi Leonard,
Lissette C.
--- In vantage@yahoogroups.com, "Len Hartka" <len.hartka@...> wrote:
> Good Day Lissette:
> We are just about to implement E9.
> Can't you do what you are doing with their 'tools" rather then Line
> code?
> Or, is what you sent the tools output?
> Or is line code the only possibility?
> len.hartka@...
> Leonard C. Hartka, IT Director\ERP Manager
> Sun Automation Group
> 66 Loveton Circle
> Sparks, Md. 21152
> 410-329-3560 ext. 120
> 410-329-3564 FAX
> 443-255-7192 Work Cell
> len.hartka@...
> www.Sunautomation.com <http://www.sunautomation.com/>
> Of liss_c
> Sent: Friday, December 04, 2009 2:06 PM
> Subject: [Vantage] BAM alert program
> Hi everyone, I am trying to create a program that will allow me to send
> an email to the dispatcher/requestor when a requisition is
> submitted/approved. This is what I have so far:
> /* This is a BAM program for the ReqHead table */
> {D:/epicor/mfgsys803/Server/ud/GlbAlert.i &TableName = "ReqHead"}
> define variable reqtID like MfgSys.ReqHead.RequestorID no-undo.
> define variable currID like MfgSys.ReqHead.CurrDispatcherID no-undo.
> define variable reqtEmail like MfgSys.UserFile.EmailAddress no-undo.
> define variable currEmail like MfgSys.UserFile.EmailAddress no-undo.
> /* By default do not send an email */
> assign SendEmail = FALSE.
> assign Email-Text = "You have a Requisition Action pending:~n".
> /* Values */
> assign reqtID = MfgSys.ReqHead.RequestorID
> currID = MfgSys.ReqHead.CurrDispatcherID.
> if (MfgSys.ReqHead.CurrDispatcherID = "":U)
> then do:
> assign SendEmail = TRUE
> Email-To = "UserFile.EmailAddress"
> Email-Subject = "[Test] ReqHead Is Working!!!"
> Email-Text = Email-Text + " ~n":U
> + " From: ":U + reqtID.
> end.
> But I still need to trigger the ther information that is not available
> in the Requisition table.
> Thanks,
> Lissette
> This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
