How we have the solution for using backflush job material with LOT controlled part in Epicor Kinetic?
Ps. found this note —Backflush Prerequisites:
The part must be coded as backflush.
The part must have a primary warehouse and primary bin.
The material requirement must be attached to a job operation.
The operation must have a labor quantity reported against it.
Labor entry must be accurate and timely.
IMPORTANT ------>>>>> Serial number controlled, lot controlled, or dimensionally controlled inventory CANNOT be backflushed.
Have you looked at the Kan Ban capability? You CAN “backflush” and provide lot information. If the manufacturing process is relatively short (less than a day) then it can be a viable option.
Hey
I am not sure if you can write scripts or code but if you could get the job numbers and lots into a csv file you could use dmt to issue the material this is basically a backflush….
Want to backflush lots (which Epicor does not do, only Kan Ban can but jobs are open too long for that)
Might be issuing multiple lots of a single part to one job. Yes, furniture has multiple parts but I am asking that for a single job, will part “A” have more than one lot issued to a single job over those two to three weeks? If so, that would make a recall much larger than needed since one wouldn’t know which lot was issued to a particular piece of furniture.
First off, what @Mark_Wonsil says is correct. If you are routinely issuing multiple lots of the same material to the same job, lot control is meaningless and you are causing yourself headaches for no reason.
Most of our jobs only use 1 lot per job, but sometimes it can be 2.
We backflush all materials except for 1, which is lot controlled.
The solution we currently use:
I have a BPM form that pops up at the end of labor actifity and prompts the operator for some info, including the lot # used for the job.
I use this data to populate a dashboard that shows all jobs that have been run with a balance of this lot controlled material waiting to be issued. The dashboard has 2 tabs, one is formatted for analysis, to highlight issues (operator data entry error, lot entered by operator at end of activity does not match lot currently at machine, etc) the second tab is formatted for DMT, so the user can, after resolving any issues, just export and upload.
This is as close as we have gotten to automating this annoying thing. I am reluctant to do this with code so I am interested in this discussion as well.
