AutoPrint Packing Slip in v9.05.607B
Auto-print is not an easy thing to get working, IMO. I have accomplished some simple receiving labels recently, committed to memory now, you have to have all the stars in the universe aligned for it to work properly. I posted a file, in the general files, not in any subfolder titled "Epicor 9 & BarTender.docx". It gives good basic understanding of how it should work on 9.04.507A, although even those instructions can be tweaked and fine tuned. testing and validating conditions is important, and making sure all the paths are correct. Go ahead and send over the screen shots if you want me to take a stab... I might be of no assistance but couldn't hurt.
--- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@...> wrote:
> In version 8.03.409c,
> - We duplicated it but in BAM you cannot select the reportID of the customized report saved in RDD.
> We have the report ID listed as the box shown as "Duplicate of" in the RDD and the Data Definition ID is the "Code" of the RDD. We are using a customized RDD.
> - Rules seem redundant between BAM and RDD. Do we really even NEED BAM?
> We have most of our rules in BAM, just a couple (they are duplicates) in RDD
> I have screen shots of all the relevant screens which I'm happy to send if someone who has accomplished auto-print would be willing to review.
> We only have one report autoprinted and it outputs plain text (not XML for Crystal), but I can compare with your screens if you want to send them...
> Karen Schoenung
> kschoenung@...
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of reptcon
> Sent: Thursday, April 05, 2012 8:52 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: AutoPrint Packing Slip in v9.05.607B
> We are experiencing very similar problems, a year later, in 9.05.607B. We cannot get the standard pack slip to print, let alone a customized one which we ultimately need (with several variants by Customer). I have yet to see it even appear in the system monitor.
> We have done all the steps we can think of (BAM -> RDD -> Report Style -> New "Printer" setup) and can neither auto-print nor preview a packing slip.
> The process appears to be fraught with "gotchas" and "Catch-22's" on which I am too frazzled to elaborate. Well I'll try:
> - In RDD you cannot customize the base [x] system report definition. OK I can understand that.
> [This makes me think that it is ONLY possible to auto-print predefined system reports (as defined by Epicor) using BAM. But we can't even get that much to work.]
> - BAM IS firing because we are receiving a [x] Email alert, but there is no evidence whatsoever of the report running. No error message either.
> It is all very frustrating.
> Thanks!
> Chris
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Chris Thompson <chriselectrix@<mailto:chriselectrix@>> wrote:
> > Hi Vic,
> > We have had this issue a few time before.
> > We were getting it where we could print and preview manually and preview from
> > the system monitor. It would print to any printer.
> > When we tried to auto print, nothing came out the printer.
> > In the end after exhausting every possibility, we changed the printer and it
> > worked straight away.
> > We were using a Brother which worked (but the printer broke) - We then swapped
> > to a Ricoh which didnt work with auto-print (tried a few Ricohs), we then
> > switched back to a new Brother which worked straight away.
> > Even tried changing the page setups in Crystal for the new printer but nothing
> > happened.
> > This sounds like exactly the issue we had.
> > The only other time we have had something similar was when we were on a previous
> > version (9.04.503b) and we actually got errors in the System Monitor.
> > I would try different printers.
> > Possibly something to do with PCL-6 or something. Dont really know much about
> > PCL-6 etc, but I think the Brother's are 5 (something - I think).
> > Hope this makes sense.
> > Thanks,
> > CHRIS
> > ________________________________
> > From: Vic Drecchio <vic.drecchio@<mailto:vic.drecchio@>>
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Sent: Thu, 28 April, 2011 18:21:49
> > Subject: [Vantage] AutoPrint
> > Â
> > Hey group.... Need some help with AutoPrint. (Vantage 8.03.408B SQL)
> > It's been a while, but I recall it was fairly straight forward. Maybe
> > not.
> > This is what I've done so far and it's not working:
> > Set up the Printer in Printer Maint. Make a new Report Data Definition,
> > set it to auto print (create the condition).... create the BAM, point
> > the bam to the RDD.......
> > I'm not getting anything printing (or auto-previewing). Just trying to
> > simply auto-print a packslip once it's shipped using ReadyToInvoice.
> > I've confirmed the BAM is firing because I also set it to do a ChgLog
> > entry and it's logging changes on the exact same condition... So the
> > BAM is firing. The XML is generating and sitting in the \reports folder
> > for the specific user. That tells me the RDD is working.
> > What's NOT working is either the Auto-Preview or the AutoPrint.
> > Nothing's printing out or previewing.
> > We've set up the printer as a "local" printer on the Vantage server as
> > an IP Port. I've confirmed that it works.
> > But even if the Auto-Preview isn't working, it tells me something is
> > breaking before it attempts to print or preview.
> > Crystal Runtime issue? Any ideas? Tried it on multiple workstations
> > and the server with the same results.
> > One other odd observation, in System Monitor, the task is Active and
> > then moves into History and says complete. But it DOES NOT show up on
> > the Reports tab of SysMon like it should be.
> > The Packslip prints/previews fine manually.
> > Thank you in advance.
> > Vic
not.
Vic
Are you seeing any errors in the System Monitor on the History tab? You should see the print job on the Reports tab - try manually re-printing from there - maybe it will give you a clue
> not.
> Vic
Vic,
Youre not a victim of your lack of knowledge..youre a victim of an
undocumented feature.. When we were on 407a we experienced the same
thing.. and got assigned a nice little SCR# for it, I understand youre
on 408b..but read the response..
55106 .409 30393MPS - TECH - PRINT Auto Print pack slip not working
after up
Added:
6/4/2009 3:50:13 PM
By:
MENGLUND
Summary:
Outgoing E-mail
Please reference call # 4055379MPS if you have any additional questions
on this issue.
Hi Rob,
I have submitted this to development and they have attached to this scr
#55106 that is scheduled to be released with the 8.03.409 service pack.
I will put this call in that queue so you are notified when it is
released.
Regards,
Mike Englund
Technical Support Analyst
www.epicor.com
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Vic Drecchio
Sent: Thursday, April 28, 2011 12:22 PM
not.
Vic
Hi Vic,
happened.
CHRIS
Â
not.
Vic
Thanks!
Chris
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi Vic,
> happened.
> Thanks,
> CHRIS
> From: Vic Drecchio <vic.drecchio@...>
> ÂÂ
> not.
> Vic
Karen Schoenung
kschoenung@...
Thanks!
Chris
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Chris Thompson <chriselectrix@...<mailto:chriselectrix@...>> wrote:
> Hi Vic,
> happened.
> Thanks,
> CHRIS
> From: Vic Drecchio <vic.drecchio@...<mailto:vic.drecchio@...>>
> Â
> not.
> Vic
